Author Topic: Mame output info needed  (Read 1915 times)
jhonny_d
  • Last login:February 12, 2019, 10:21:06 am
« on: December 07, 2016, 06:53:34 am »
Hello, I'm toying with a few ideas regarding exotics controllers :) and I need some info about mame output possibilities
1)Aimtrak guns kickback each time a shot is fired, would it be possible to set up everything so the recoil is activated only when there are bullets in the magazine ?
2)Does mame supports analog outputs? I would like to create a Densha De Go panel which uses analog speedometers
jhonny_d
Re: Mame output info needed
« Reply #1 on: December 08, 2016, 09:20:00 am »
Done some research, about question one, would mame hooker combined with an output board like the pac-drive allow me to control the gun solenoid?
jhonny_d
« Reply #3 on: December 08, 2016, 10:22:13 am »
thanks, from what I get that's possible
unfortunately I tried mamehooker and wasn't able to detect any output with all the roms I tried
« Reply #4 on: December 08, 2016, 10:29:44 am »
I think outputs were messed up/deleted in MAME for some recent versions.
Pretty sure there's a thread about it in the software subforum.
You might try a version around the 150's, or see what version charlieram is using.
EDIT: Also keep in mind that MAME is made up of a bunch of different parts, meant to emulate different arcade hardware, written by a lot of different people.
Some games have the outputs emulated, some (most?) do not.
« Last Edit: December 08, 2016, 10:33:11 am by BadMouth »
jhonny_d
« Reply #5 on: December 08, 2016, 11:23:33 am »
thanks for the help, probably it's the mame version fault, since I tried dig dug that's used from howard casto as an example in the tutorial
  • Last login:Today at 06:18:49 pm
« Reply #6 on: December 08, 2016, 01:52:41 pm »
I made it a point some years ago to hook up any gun game I possibly could.  So unless it has been removed, it's a Namco game, or the game never had outputs to begin with you should have some outputs to work with.
