Author Topic: Help CRT to PC NOOB.  (Read 3746 times)
Johnnyconquer
  • Last login:April 27, 2017, 08:41:59 pm
« on: December 07, 2016, 04:59:31 am »
Hello everyone first let me say if this is posted in the wrong place I apologize having monitor/video issues so i came here.
I have exhausted my limited knowledge in setting up my new cab and hoping to get some input from the pros.  ;D
Going to give as much detail as possible without being confusing.
I recently acquired a new arcade cab with a wg25k7191 Monitor. The monitor is spliced to a VGA Cable.
It's a rarer Gargoyle cab that actually ran off of a real Sega Genesis console so there is no Jamma or Jpac or anything else inside. (I still have the original guts but they were removed and the cab was modded for a mame setup hence the vga splice.)
When I received it there was an older mame computer with an arcade vga card but that system was not working from the beginning. Pulled it out couldn't get motherboard or card to work.
I decided to start with a new system all together from what I had gathered I decided to run a windows 7 dual core pc with a ati radeon hd4350.
I wanted to use the most recent version of emudrivers This is the link text. http://aburamushi.net/calamity/crt_emudriver_&_tools_2.0_beta_8_12.6_W.7.8.10-64.exe
I see that its a beta I did try the older one as well that one wont work at all for me. Link text. http://mame.3feetunder.com/windows-ati-crt-emudriver/crt_emudriver_13.1_1.2b_w7_64.exe
I have also tried soft 15hrtz with quick rez. Did not work. Link Text from that source. http://retrorgb.com/rgbvideocard.html
So whats happening is the crt picture is split down the middle and scrolling up and down. The same end result with every way i tried.
This leaves me with several questions.
1 - Is it the graphic card and can I run straight from the PC to the monitor or do i need additional hardware in between like a jamma or jpac? I have read that this card can be a problem but also its the best. Same model as the walk through i used.  Ati Radeon hd4350. Its blue instead of red most of the ones i have seen are red idk why mine is blue.
2 - Is it the software? This is the guide i used. http://geedorah.com/eiusdemmodi/forum/viewtopic.php?pid=1016
I did it all from one pc monitor instead of using two.
I don't even have groovy mame yet I just wanted to get the picture working first. Any kind of clear picture. Do I need groovy mame yet? I don't think so.
3 - The monitor. When I turn it on I can hear it. Sounds like turning on any old tv unattached it stays pure black no flashes or anything. When I turn it off a blue box that comes from all four corners shrinks into nothing in about a second. I think that's normal. I can send pics if it helps. Is there a way to troubleshoot the monitor maybe to rule it out? I don't think its broken but definitely a possibility.
I have put about two weeks into this an I'm a little defeated. Any help would be VERY much appreciated because I don't think I can find anyone that can help with this kind of project outside the internet. Willing to send pics, videos whatever it takes I'm getting this thing working its such a shame sitting here unusable.
Thank you I will reply quick as possible.
  • Last login:February 17, 2026, 02:43:50 am
Re: Help CRT to PC NOOB.
« Reply #1 on: December 08, 2016, 12:13:24 pm »
Some pics of even better a video of the garbled screen will certainly help.
You should follow the guide verbatim unless you know what you're doing. That's the purpose of the guide.
Johnnyconquer
« Reply #2 on: December 08, 2016, 07:54:00 pm »
Ok awesome gonna get you some pics asap. At work right now. And I'll also run through the process all the way with two monitors. I appreciate the reply!
Johnnyconquer
« Reply #3 on: December 09, 2016, 02:42:03 am »
Ok trying to post vid and pic after following the guide the correct way. But it wont let me post anything keeps saying files too large -_- The end result is a fast scrolling screen. Hope this link works to a pic. The black diagonal bar in the pic isnt really there so much just a fast scrolling screen. http://i1042.photobucket.com/albums/b426/John_Finucan/IMG_39801_zpsibtj9vbw.jpg *Update* Here's the video
« Last Edit: December 09, 2016, 03:44:29 am by Johnnyconquer »
« Reply #4 on: December 09, 2016, 04:33:47 am »
Ok no need to mess with the software by now.
It's a vertical sync problem. On your monitor chassis, there must be a little board with potentiometers, find the one named V-hold. Try adjusting it with care until the picture stops rolling. If you can't achieve that, then focus on the cable.
« Last Edit: December 09, 2016, 04:35:58 am by Calamity »
Johnnyconquer
« Reply #5 on: December 09, 2016, 02:08:50 pm »
Ok thank you I adjusted the knob it's barely scrolling now. It's flashing. Which cable should I check the spliced vga or the ones to the pots? http://s1042.photobucket.com/user/John_Finucan/media/6AFB0FB2-4860-440F-972A-082CD8210608_zpsphxgnz0h.mp4.html
« Reply #6 on: December 09, 2016, 04:06:08 pm »
The spliced vga cable. You need to determine how the h-sync and v-sync lines from the vga are wired to the monitor. Notice your monitor can handle separate (negative or positive) and composite sync. Different pins are used on the chassis. A default installation of CRT Emudriver 2.0 outputs negative sync (separate). If your monitor is expecting composite sync, then both h and v links should be wired together.
Johnnyconquer
« Reply #7 on: December 09, 2016, 05:18:28 pm »
Alright first off thanks so much for the responses. Is there a diagram anywhere for these wires I don't know what color is what.
I unclipped the cord from the board. http://i1042.photobucket.com/albums/b426/John_Finucan/27232475-8B7D-42DE-8F80-B89EB9113E95_zpsaei6dah7.jpg
Undid the tape. http://i1042.photobucket.com/albums/b426/John_Finucan/82A6977E-A749-435A-92B2-B4AC36964A2B_zpsqcxfenia.jpg
Here's what is soldered. The little hairs are from the tape. http://i1042.photobucket.com/albums/b426/John_Finucan/6C7AA5F4-ADEA-402A-B22B-2F3252672783_zpsofwapmna.jpg
There's a black wire that's just clipped and not attached to anything coming from the monotor end. None of the wires coming from the monitor side are together so that might be the problem if I can locate the h and v link colors. Does any of this look right or was it a bad wiring job?
*Update* Found this gonna see if I can troubleshoot. https://www.google.com/amp/www.instructables.com/id/MAME-Cabinet-in-4-key-steps/step2/VGA-to-the-Arcade-Monitor-hookup/%3Famp_page%3Dtrue?client=safari
Ok after looking at everything it looks like this is a special vga cable labeled for doing this kind of job. The h and v wires do look to be in fact wired together to the white monitor wire. The monitors side only has green red brown white and a regular wire I'm assuming is power.
« Last Edit: December 09, 2016, 05:50:48 pm by Johnnyconquer »
« Reply #8 on: December 09, 2016, 06:14:23 pm »
Check this link: http://www.jstookey.com/arcade/WG_25k7191/
Check specifically which sync pins on the chassis are being used. You have pins for positive and negative polarity. The negative ones should be used.
Johnnyconquer
« Reply #9 on: December 09, 2016, 07:59:07 pm »
Ok starting to get complicated but im gonna figure it out. lol His is connected to the pins different but he doesn't have a power wire incorporated like mine does. He also has two separate pin connectors. Is there somewhere i can buy a new monitor cord to start over or is it hand made. I found the vga cable on a couple sites but cant find the monitor cable with the pin connector. I'm kind of confused because he has the negative h and v going to his video card so he can use a light gun.
« Reply #10 on: December 10, 2016, 05:34:49 am »
You need to find a manual for your exact chassis.
In the meantime, it would be of help to have a CRT pc monitor,  so you can connect it to the garbled output and read the actual frequencies on its osd, just to discard other stuff.
Johnnyconquer
« Reply #11 on: December 10, 2016, 08:44:17 am »
I have the manual I can see where all the pins need to be connected. I'm down to a few variables. The v and h wires together are going to the h positive pin. I could try it to the v positive or try seperating them back to there original pins. But there's also v and h negative. I think I should be using positive. I don't understand why people solder them together instead of just keeping them separate to their original pins. I need to get a new pin connecter because this one has the 5th connector (v) removed. I'm gonna try and get a crt pc monitor tomorrow if I can't get it working.
« Reply #12 on: December 10, 2016, 02:41:34 pm »
The v and h sync cables are wired together to mix the signals and create composite sync. Your chassis acceps composite sync through the h pin, either positive or negative. The issue going on there is your PC is outputting negative sync, but the cable (h+v) is going to the h positive pin, which expects positive composite sync.
So basically your options are:
- Connect the cable (h+v) to the h negative pin, or
- Change the polarity of all your video modes to positive with CRT Emudriver (VMMaker), or
- Split the sync lines and connect them as negative separate sync, h- and v- pins (not worth probably).
Johnnyconquer
« Reply #13 on: December 10, 2016, 07:54:01 pm »
Ok After some high tech engineering I separated the pin connector from the harness and put the hv wire from positive to the negative pin. http://i1042.photobucket.com/albums/b426/John_Finucan/FD9AD570-85DA-4A78-A9EB-DCBE013B8266_zpsyl1xbhye.jpg
http://i1042.photobucket.com/albums/b426/John_Finucan/0986C4DA-C770-4B30-9B72-346934A5E988_zpsbavrv8ct.jpg
The scrolling has stopped completely but it's still flashy and garbled. The resolution is 640x 480. http://s1042.photobucket.com/user/John_Finucan/media/D8351378-7728-4844-BA15-099C60B1F353_zpscfwm0zie.mp4.html
We have come a long way I'm not giving up!
« Last Edit: December 11, 2016, 01:01:38 am by Johnnyconquer »
« Reply #14 on: December 11, 2016, 12:32:01 pm »
Maybe you need to readjust the v-hold potentiometer since you messed with it in previous steps.
Johnnyconquer
« Reply #15 on: December 11, 2016, 01:54:46 pm »
 :applaud: Hell yeah it worked! I can't thank you enough looks like it still needs some tiny adjusting but it's pretty much fixed! http://i1042.photobucket.com/albums/b426/John_Finucan/16860018-DF5E-45FD-AF5E-85431C310384_zps4denqfcq.jpg
I'll come back if I can't get it. Thank you again you really saved me a lot of time and frustration. I'm sure I'll be back on the forums trying to get something else set up. Lol so glad I didn't have to mess with the caps. This really made my day spent over two weeks getting a computer and hyperspin to work just to find out the monitor was messed up took me about 3 weeks but now I can play some games!
« Reply #16 on: December 11, 2016, 02:12:03 pm »
Glad that it worked. I really wonder what the previous owner did to get it working.
acvieluf
  • Last login:February 10, 2026, 08:01:11 pm
« Reply #17 on: December 11, 2016, 08:21:26 pm »
Congratulations! Feel free to join us over in the high score competitions sometime!
Sent from my Atari 2600
