Author Topic: Robocop Vs Terminator  (Read 17925 times)
  • Last login:February 22, 2026, 06:49:16 pm
Re: Robocop Vs Terminator
« Reply #40 on: February 24, 2017, 01:08:09 pm »
mafiafan123
  • Last login:March 01, 2022, 01:13:01 pm
  • i'd buy that for a dollar
« Reply #41 on: February 24, 2017, 01:22:11 pm »
This is the one I use & sell:
http://shop.harumancustoms.com/power-inlet-switch-fused-module
HaRuMaN I'll grab one if I send you a picture of wires can you help me with a diagram? I might swap out the one I have for a surge protector vs just a regular strip and then use your switch
« Reply #42 on: February 24, 2017, 01:30:03 pm »
Yeah I should be able to help.   :cheers:
  • Last login:Today at 06:16:59 pm
« Reply #43 on: February 24, 2017, 02:25:45 pm »
It's pretty easy if you use the diagrams in the wiki.
https://web.archive.org/web/20150928061832/http://newwiki.arcadecontrols.com/index.php?title=Wiring#IEC_Fused_Power_Inlet_with_a_Lighted_Switch
Just make sure you have clean, corrosion-free, mechanically-solid and low-resistance (<2 ohms) power connections.
You want a low-resistance connection to avoid generating heat like this.
mafiafan123
« Reply #44 on: February 24, 2017, 02:30:16 pm »
That looks nice and toasty I read your post about the cable and stuff that's crazy. I would hope to never smell anything burning!
mafiafan123
« Reply #45 on: March 02, 2017, 01:00:11 am »
Testing some led lighting.
I secured the marque retainers with magnetic tape surprisingly it holds well I reinforced it with some glue but it doesn't show at all.
Ordered speakers as well and a Pyle amp this time instead of kinter read it had better reviews.
Still debating putting a cam lock on the back door I purchased a piano hinge and magnets but I like the key aspect of it.  I'll post better pictures later on.
Word of advice the Xin Mo encoders are ok but not ideal luckily there are some great devs who created xpadder joy to key etc or I would be lost!
Also does anyone know of a SUPER SILENT  80 or 120 mm fan thinking of putting two on the back all of the silent labeled ones seem to be really loud even turned down
« Last Edit: March 02, 2017, 12:16:20 pm by mafiafan123 »
firedance
  • Last login:Today at 09:52:59 am
« Reply #46 on: March 03, 2017, 12:58:56 am »
do you have fan grills installed ? they can create loads of noise with the wind rushing through.
i normally use arctic fans for my pc towers, never had a problem with them - https://www.arctic.ac/uk_en/arctic-f12-pwm.html or https://www.arctic.ac/uk_en/arctic-f8-pwm.html both are PWM ones, depends on your motherboard support.
mafiafan123
« Reply #47 on: March 03, 2017, 01:03:01 am »
No I do not have a fan grill installed was thinking of mounting it to the wood with a spacer and putting a fan filter on it, or would I not need this since I'm technically using to draw heat out?
firedance
« Reply #48 on: March 03, 2017, 01:05:56 am »
wouldn't have thought you need a fan filter on the exhaust fan, i did use some little O rings on one tower i built to reduce the vibration, could have used these as well https://www.quietpc.com/afm02b-group.
mafiafan123
« Reply #49 on: March 18, 2017, 11:25:01 pm »
Please don't bash the wiring as I will fix but I wanted to test.
Can someone please see if this is correct I wired using this diagram
And have attached pictures the switch lights up but the strip is not working
Wired
Thanks! I'm ready to show this thing completed lol
mafiafan123
« Reply #50 on: March 18, 2017, 11:28:27 pm »
Lol never mind it's one of those nights did you flip the switch haha.
Turned it on. It works ha.
I need more sleep
« Last Edit: March 19, 2017, 02:20:41 pm by mafiafan123 »
mafiafan123
« Reply #51 on: March 26, 2017, 10:30:05 pm »
Im calling this done just have the forever long software battle now
I'm sure I will always find something else to do to it next, thanks everyone that helped!!
