Author Topic: Struggling to Get MaLa to let me direct it to my roms folder  (Read 8212 times)
NaptownChief
  • Last login:December 23, 2016, 11:10:33 am
« on: December 04, 2016, 10:41:51 pm »
Seems like this should be a very simple and basic task but I'm in the Options setup pop up box after running a new install and it lets me point it to the correct folder for the MAME executable folder but when I click on the "..." to direct it to my roms it doesn't allow me to do so.  It just looks like an empty folder that only gives me the ability to click "Open" which does nothing or just hit "Cancel".  Yet the folder is loaded with unzipped roms as I have triple checked and always visiable expect when I try to link MaLa to the folder.  Thanks in advance for helping with what appears to be a stupid question.
« Last Edit: December 04, 2016, 10:43:35 pm by NaptownChief »
  • Last login:Today at 12:26:36 pm
Re: Struggling to Get MaLa to let me direct it to my roms folder
« Reply #1 on: December 04, 2016, 11:55:55 pm »
Welcome board, NaptownChief.   ;D
MaLa is looking for an XML file (lower right in your first screenshot), not the ZIP files in your second screenshot.
MAME's XML format changed in version 0.162 -- if you're using that version or newer, check out the workaround here.
« Reply #2 on: December 06, 2016, 09:51:54 pm »
Welcome board
haha, you called him a piece of wood.
NaptownChief
« Reply #3 on: December 11, 2016, 11:58:53 am »
Thanks. Forums like this is what gave me the confidence to build my cabinet several years ago. For a non techie like me do you think it would be wise to just use an older version?
« Reply #4 on: December 11, 2016, 08:04:13 pm »
It would be easier if you don't have to do the XML workaround, however it might be worth the effort to use a newer version if MAME has added a feature or game that you can't live without.
Check out the "What's New" files here.
NaptownChief
« Reply #5 on: December 11, 2016, 09:15:17 pm »
Thanks...I finally got it working with .179.  Now I am just fighting with getting a custom MaLa layout working.  Baby steps.
NaptownChief
« Reply #6 on: December 12, 2016, 08:27:24 pm »
New issue.  When I went into the MaLa options/configuration and then selected "Game Collection Options"  and then selected "Only Games Found In Roms folder" all the games no longer show up.  If I toggle over to the "Games Most Played" and it will show the 6 to 10 games I did previously play but none other than those.  I went back and reversed that change and still not there.  Refreshed the game list and still nothing.  Went into MAME and ran an audit and refresh.  Still nothing.  Thoughts?  Thanks
NaptownChief
« Reply #7 on: December 12, 2016, 11:13:31 pm »
I started over from scratch and did the XML fix you posted and that worked.  Thanks a bunch
