Author Topic: Will a vertical CRT work with light guns + CRT compatability  (Read 1091 times)
oxygenaddict
  • Last login:January 11, 2017, 07:24:22 am
« on: November 29, 2016, 12:16:19 am »
It may sound dumb but if I lay a CRT on its side, will a light gun still accurately detect where Im shooting?
Plus, will a Sony KV-32HS510 work with light guns?
I know some of the newer CRTs wont work with them but I havent found any info yet on how to tell
Endprodukt
  • Last login:Today at 03:54:23 pm
Re: Will a vertical CRT work with light guns + CRT compatability
« Reply #1 on: November 29, 2016, 04:46:42 pm »
TOTALLY depends on the lightguns you're going to use. I can't think of any vertical lightgun shooters, though.
matsadona
« Reply #2 on: November 30, 2016, 04:51:08 am »
Well, if there is any external positioning device (IR leds etc.) that has to be re-orientated as well... If it is based on CRT synchronisation it wouldn't be any difference.
In what context did you get to this question?
As far as I know you get problems with never CRT's if they are 100Hz and other stuff that messes up the timings.
