Author Topic: Is there a list of ROMS supported by Raspberry Pi 3  (Read 6958 times)
Ortizimo
  • Last login:July 10, 2024, 07:26:45 pm
  • USAF Retired Veteran (1995-2015)
« on: November 27, 2016, 03:50:18 pm »
I always wondered if I should go with the raspberry pi or a regular mobo. Is there a list of ROMS supported/not supported by the latest Pi?
Sometimes, when it's quiet, I can still hear the monkeys." - Guybrush Threepwood, Mighty Pirate.
Slippyblade
Re: Is there a list of ROMS supported by Raspberry Pi 3
« Reply #1 on: November 27, 2016, 04:15:35 pm »
Has nothing to do with the version of Pi, it's to do with the version of MAME you are using.  Figure out the MAME version and then just Google up the DAT file for that version and run it through ClrMAMEPro to fix your ROM set to the correct version.
Ortizimo
« Reply #2 on: November 27, 2016, 04:20:31 pm »
so raspberry pi can run street fighter alpha, etc?
Slippyblade
« Reply #3 on: November 27, 2016, 07:28:34 pm »
Keep in mind that "can run" and "runs well" are different things.  The most common version of MAME on the Pi2, I believe, was .037...  The Pi3 is way more powerful, but I'm not sure if there is a binary available for a more advanced version of MAME yet.  Probably, but I've not looked.
  • Last login:Today at 12:12:31 pm
« Reply #4 on: November 27, 2016, 07:37:10 pm »
Here's a list of arcade emulators in RetroPie and associated ROMset versions.
https://github.com/RetroPie/RetroPie-Setup/wiki/Managing-ROMs
Check out the "Compatibility List" links in the right column.
ivwshane
    • My first mame cab! (WIP)
« Reply #5 on: November 28, 2016, 11:31:50 pm »
Raspberry Pi 2 and three both run street fighter 3, all versions, at full speed.
