Author Topic: Ideal thickness of material  (Read 3556 times)
sleong
  • Last login:December 26, 2021, 04:11:56 pm
  • Novice builder of Arcade Machines
« on: November 17, 2016, 02:08:06 pm »
Greetings everyone,
What thickness of material is good to use when building cabinets either bartop/table top or full size?
I'ce only built a bartop once with 3/4 particle board. Why?  Because the material was free. I did not use T-Moulding.  I just left the edges with a straightcut and used the glue on siding and routed the edges so there would be no sharp edges.
Now I am considering a full size and want to see what thickness material is ideal. I may need to buy material this time so I want to buy right the first time.
I still have some partical board left but not in full sheets for a full size cabinet. Only good for bartop size and/or mini size cabinet. In which I may do for the kids.
Thanks in advance.
Steve
thomas_surles
Re: Ideal thickness of material
« Reply #1 on: November 17, 2016, 02:10:47 pm »
3/4 and 1/2
  • Last login:October 11, 2025, 02:57:11 pm
« Reply #2 on: November 17, 2016, 02:25:45 pm »
nearly all wood arcade cabinets are 3/4" particle board. standard t moulding is 3/4". no reason to use anything else. the only thing i've seen NOT 3/4" is the tops of cocktail tables which are usually 1 inch.
as for materials some people prefer 3/4 MDF while others go the plywood route.
if you want to eschew the t-moulding, and route the edges again, MDF is more consistent all through the entirety of the material and would leave a nice edge.
if you want to just whack something big together, a good one side plywood is plenty strong, and doesn't need much prep to paint or anything like that, and could even be stained.
when it comes down to it, personal preference and ability to work with a material are basically the limiting factors.
I personally buy sheets of 3/4 black laminate particle board that are laminated on both sides. you have to be careful not to scratch or gouge it and need to use a sharp blade when you cut it so the edges don't get chipped... but the result is a nice surface that needs nearly zero work in finishing.
I think if I where to use something less than 3/4" would be a mini or micro sized build... and i'd probably go 1/2" with it. not that there is anything wrong with using 3/4" but more to keep the weight down and maybe give a tiny extra bit of space inside if I were trying to keep a certain dimension outside.
paigeoliver
  • Awesome face!
« Reply #3 on: November 17, 2016, 02:42:00 pm »
Everything is 3/4" except for a few early 80s import Asian cabinets which were more like 11/16.
  • Last login:July 23, 2025, 07:04:20 pm
« Reply #4 on: November 17, 2016, 02:46:19 pm »
All my bartops I sell are in 1/2".  T-molding.com now has lots of colors of T-molding in 1/2", including chrome.
When I do bigger cabinets, cabaret or full size, I do 3/4".  :cheers:
paigeoliver
  • Awesome face!
« Reply #5 on: November 17, 2016, 04:15:25 pm »
Real industry bartops however are 3/4".
fablog
  • Last login:October 11, 2025, 09:46:57 pm
« Reply #6 on: November 17, 2016, 06:51:51 pm »
5/8" if you laminate yourself and put a t-molding.
« Last Edit: November 17, 2016, 06:53:46 pm by fablog »
