Author Topic: Shell...  (Read 1695 times)
Nightmare03
  • Last login:August 18, 2007, 07:20:34 am
  • Stupid llama!
Shell...
« on: January 21, 2004, 02:49:05 pm »
Can somebody make a program, which is black and launches C:\Program Files\MAMEWAH\MAMEWAH.exe ? Also, this needs to be able to be the shell...
I tried using visual c++ but i cant even change the background color!!! could i get anymore useless?  ???
Jakobud
  • Last login:December 23, 2025, 02:48:26 am
Re:Shell...
« Reply #1 on: January 21, 2004, 03:54:40 pm »
Huh?
Nightmare03
  • Stupid llama!
Re:Shell...
« Reply #2 on: January 21, 2004, 05:45:53 pm »
nevermind dude ill make it myself in visual c++
TalkingOctopus
  • Last login:August 04, 2025, 03:48:02 am
    • My Arcade
Re:Shell...
« Reply #3 on: January 21, 2004, 06:30:20 pm »
Just trying placing a MAMEWAH shortcut in the windows startup menu.
Random24
  • Last login:December 22, 2024, 01:51:59 pm
Re:Shell...
« Reply #4 on: January 21, 2004, 07:21:59 pm »
Have you seen this thread?
I have posted how to run a front end as a shell a few times now.  I use Dragon King in my cab as a shell and I have Virtual Music Jukebox as the shell in my Jukebox.  It's pretty easy to setup just about anything as a shell in all versions of windows going back at least to 95 and maby even further.  ( I don't know because before 95 I wouldn't touch windows. DOS all the way)
If you are using 98 you can just replace the shell=explorer.exe in the system.ini with shell=(put the path and exe name to your front end here)
Nightmare03
  • Stupid llama!
Re:Shell...
« Reply #5 on: January 21, 2004, 07:38:27 pm »
Dude, windows 98 cant use visual basic programs as a shell... like mamewah
Minwah
    • MAMEWAH
Re:Shell...
« Reply #6 on: January 21, 2004, 07:43:27 pm »
Yes it can :)  I know MW used to work fine as a shell, not sure about the last handful of revisions because I don't actually test that (don't have a '98 PC for one thing)...
Nightmare03
  • Stupid llama!
Re:Shell...
« Reply #7 on: January 21, 2004, 08:05:04 pm »
well dude, the mamewah i have doesnt work as a shell
Minwah
    • MAMEWAH
Re:Shell...
« Reply #8 on: January 22, 2004, 08:28:43 am »
What doesn't work about it exactly?
Nightmare03
  • Stupid llama!
Re:Shell...
« Reply #9 on: January 22, 2004, 03:59:41 pm »
I change "Shell = explorer.exe" to mamewah then when you restart it says somethin about you have to reinstall windows.
so i just went into command prompt and changed it back.
Random24
Re:Shell...
« Reply #10 on: January 22, 2004, 04:30:37 pm »
did you just put
shell = mamewah.exe
or did you (as I said is needed) put
shell = "c:\directory where program is installed\mamewah.exe"
If you tried it the first way, that could be your problem.  It will work that way but the directory where mamewah is installed would need to be in the PATH statement.
Nightmare03
  • Stupid llama!
Re:Shell...
« Reply #11 on: January 22, 2004, 04:47:42 pm »
I did it the second way.
-Nightmare
Random24
Re:Shell...
« Reply #12 on: January 22, 2004, 05:30:37 pm »
does your directory path have spaces?  If so you may have to put quotes arround it.
Like "c:\program files\mamewah\mamewah.exe" (notice the space in program files)
I hate the way windows lets you use spaces in directory and file names and then doesn't handle them correctly unless you put quotes arround them.  I have seen this cause problems countless times.
« Last Edit: January 22, 2004, 05:33:37 pm by Random24 »
