Author Topic: UltraStik 360 Ball Top  (Read 1407 times)
steved61
  • Last login:October 19, 2025, 01:05:53 pm
« on: November 15, 2016, 08:02:25 am »
Am I better off using the UltraStik 360 wiring harness or the Ipac4 for players 1 and 2 Buttons ?
Steved61
wasted0101
  • Last login:May 01, 2021, 02:29:55 pm
Re: UltraStik 360 Ball Top
« Reply #1 on: November 16, 2016, 10:31:12 am »
This seems like a question for Andy, have you tried to reach out to him?
SlyBlueFox
  • Last login:November 29, 2023, 12:11:50 pm
« Reply #2 on: November 16, 2016, 07:24:38 pm »
I assume you have a 4 player cab and player 1/2 have a UltraStik? Either way, it really doesn't matter I wouldn't think. The wiring harness for the UltraStik is an extra cost so that may be a reason for you or if you plan on using only MAME, I believe the ipac4 is setup for default MAME controls already so you wouldn't have to do anything extra there. Good luck either way.
steved61
« Reply #3 on: November 17, 2016, 03:14:43 pm »
Yes its a 4 player control panel.
Thinking I'd use more emulators then just MAME.
So if that's the case, I'll hook up the buttons to the UltraStik 360. That way the joystick and buttons will act like Xbox360 controllers.
SteveD61
