Author Topic: COIN ACCEPTOR  (Read 2974 times)
THE LONGPLAYER
  • Last login:November 17, 2016, 06:39:48 am
  • I build digital jukeboxes
COIN ACCEPTOR
« on: November 15, 2016, 06:16:31 am »
HI ALL
i AM IN THE PROCCESS OF BUILDING AN MP3 JUKEBOX.  MOST OF THE ELECTRONICS IS COMPLETED AND I AM NOW IN THE MIDDLE OF DRAWING UP PLANS FOR THE CABINET.
I WILL BE USING A LK100B COIN ACCEPTOR OR COULD USE THE CH926.  MY QUESTION IS, CAN EITHER OF THESE WORK WHEN NOT MOUNTED VERTICALY?
IT MAY BE THAT I WOULD MOUNT IT IN A PANEL WHICH SLOPES BACK AT ABOUT 45 DEGREES IF THIS WORKS.
ANY IDEAS OR INFO. WOULD BE HELPFUL.  THANKS
      THE LONGPLAYER
lilshawn
  • Last login:Yesterday at 11:45:41 am
Re: COIN ACCEPTOR
« Reply #1 on: November 15, 2016, 03:35:03 pm »
no they must be mounted within a few degrees of vertical otherwise it throws off the coin scan. (coins roll too fast or too slow)
if you have a sloped front, consider mounting a coin slot in the front and then having a roll down chute to a mechanism like this:
https://www.aliexpress.com/store/product/Vertical-Advanced-CPU-comparable-Coin-selector-TW800-vertical-coin-acceptor-arcade-accessories-for-coin-operator-arcede/607318_32547087482.html
then use another chute to return the coins or accept them wherever you need to.
if you must use this mechanism, consider using a plate to level out the mechanism to match the slope of your front.
I had these ones made to install an electronic mech in a rowe jukebox in the front door:
THE LONGPLAYER
Re: COIN ACCEPTOR
« Reply #2 on: November 16, 2016, 05:19:09 am »
Many thanks for your advice Lilshawn.
I did think that may be the problem with installing on a slope but glad to have that confirmed.
I will look at the other options that you have suggested.  I like the idea of a separate front plate and mounting the mech behind and vertical.
I think that there may be several types of mech. that can be installed that way and as I only want to use one coin type I should not have a problem.
Once I have a suitible mech. and a front plate on the bench, I will set about designing the chutes etc.
I will post the finished result here on this forum.
Many Thanks
The Longplayer
