Author Topic: Undetected Montior: Wells-Gardner K7000 - J-PAC - Radeon 4670 - Arch Linux  (Read 1762 times)
OverRide
  • Last login:May 04, 2023, 08:06:52 pm
Hello,
My problem is before Groovymame even starts but this seems like the most fitting place to post my problem. Please move else where if not.
As the topic states, I am running the above setup for Video. When I attempt to launch X in this configuration, X quits when it cannot find a connected monitor.
If I connect an LCD screen, start X, then reconnect back to the J-PAC with the K7000, things work fine.
Some solutions I am considering and would like some possible conformation on:
1. Circumvent the J-PAC? Go with the K7000 straight into VGA card(Haven't tried this easy test. Need to build a VGA breakout cable first).
2. Add 75ohm resistor to RGB leads? Looks like this is the solution I need, but would like to see if I can avoid it with another work around. It also causes some darkening of the video?
3. EDID dongle? Will this trick X into thinking a monitor is connected? Or only provide EDID info?
4. Use Windows? Will I have the same results with Groovymame on a Windows machine setup?
5. Is there some option I am missing which tells X to ignore non connected VGA port and start anyways?
6. Found this EDID emulator as well?
Thank you!
« Last Edit: November 14, 2016, 10:47:44 am by OverRide »
OverRide
Re: Undetected Montior: Wells-Gardner K7000 - J-PAC - Radeon 4670 - Arch Linux
« Reply #1 on: December 12, 2016, 04:01:05 pm »
I ended up ordering the EDID emulator - Solves the problem.
