Author Topic: Led Blinky Help- ipac ultimate- willing to PayPal/pay for setup  (Read 2906 times)
bcgamer
  • Last login:September 30, 2021, 02:33:37 pm
« on: November 11, 2016, 11:46:41 pm »
Just throwing it out there
I am at my wits end with the very last thing to setup, everything is done.
I have a new ipac ultimate, running SINGLE colour led's
I've wired everything up, plug in the power off the board, awesome everything lights up!
I've attempted to setup blinky with the limited amount of info that's out there, proper pins to the software layout, and the lights just stay lit.
I attempt to do an led test after mapping, dimming them all with the slider...no response.
Blinky sees the board, I can see that.
I know I've correctly mapped everything, and input it properly...but no control software side...
At this point I'm reaching out, willing to pay, as I really want to learn blinky and need someone who knows this program to set me up one time..can be by phone call whatever doesn't matter.  The whole reason I went with ultimarc because it seemed like a seamless integration.
If anyone is interested please either respond or pm me, I have no issues paying people for their time.
Thanks in advance
ed12
Re: Led Blinky Help- ipac ultimate- willing to PayPal/pay for setup
« Reply #1 on: November 12, 2016, 12:19:29 am »
are u sure u looked every where ?
a quick search on led blinky
gives this
LEDBlinky Icon LEDBlinky Downloads
This is the complete set of LEDBlinky apps for new installations:
 LEDBlinky v6.3 - Arcade LED Control Software and Animation Editor
 License Agreement
 Readme  (Includes Version History)
LEDBlinky v6.3.0.1 Upgrade
 How to upgrade:
 First, identify your current version of LEDBlinky by right-clicking on the LEDBlinky.exe file, select Properties, and then view the Details tab.
 My version of LEDBlinky is 6.0.0.0 or later:
1. Unzip all files into the folder above the \LEDBlinky folder overwriting the existing files.
2. Run the LEDBlinky Configuration application (LEDBlinkyConfig.exe). This will migrate your settings.
3. Done!
My version of LEDBlinky is between 5.1.0.0 and 5.1.0.3: 1. Unzip all files into the folder above the \LEDBlinky folder overwriting the existing files.
2. Run the Generate LEDBlinky Input Map application (GenLEDBlinkyInputMap.exe). This will migrate your input map.
3. Run the LEDBlinky Configuration application (LEDBlinkyConfig.exe). This will migrate your settings.
4. Done!
My version of LEDBlinky is between 3.7.3.0 and 5.0.0.5:
 You must first upgrade to version 5.1 before upgrading to version 6.0 (or later). 1.  Download LEDBlinky version 5.1.
2. Unzip all files into the folder above the \LEDBlinky folder overwriting the existing files.
4. Download the latest upgrade package and follow the upgrade instruction for version 6.0.0.0 or later (above).
 Note: If you are currently running a version of LEDBlinky older than version 3.7.3, you'll need to do a complete re-insallation. Please do not use the upgrade.
 Note: If you are currently running PinballX and wish to upgrade to LEDBlinky v6.2, please see this support link for additional instructions.
Just the animation editor:
LEDBlinky Animation Editor v6.3
Individual support files:
Controls.ini
Colors.ini
why could u not find it ?
also please state the system u are using it and >os<
ed
bcgamer
« Reply #2 on: November 12, 2016, 01:10:46 am »
Oh I've seen that
That's the easy part.
I'm talking about getting it to work with I/O.  I've gone through a few numerous tutorials and can't even get past the port mapping and having blinky recognize the ports it's being directed to.
I'm on Windows 10, attempting to migrate it into hyperspin once operational.
ed12
« Reply #3 on: November 12, 2016, 01:17:39 am »
ok i understand better now
thk-u
ed
bcgamer
« Reply #4 on: November 12, 2016, 01:59:35 am »
If anybody is familiar with the IO,
I never ran that WinIpacv2 config utility, I just wired up my board and went at it, controls work fine etc.
I could not find much on the utility and it's purpose... Could that be a reason?
trendy21
  • Last login:January 27, 2023, 08:11:48 am
  • Alright, Alright, Alright
« Reply #5 on: November 12, 2016, 01:01:54 pm »
Email arzoo directly he is of great help!  He will look at your log and let you know if it's his program he can help you with, otherwise email Andy at ultimarc he too is very helpful just have to be patient for responses but those two will get you up and running, arzoo has been helping me for two weeks and has taken care of everything for me when I was at my wits end!
bcgamer
« Reply #6 on: November 13, 2016, 01:43:01 am »
I'll reach out to Arzoo
Andy has been awesome, it's the the ipac that's for sure its ledblinky...hopefully he can get me sorted out
arzoo
  • Last login:January 26, 2025, 08:51:53 am
  • Robots WILL kill you.
    • LEDBlinky
« Reply #7 on: November 14, 2016, 07:14:24 pm »
When you first connect 5v power and USB to the Ultimate I/O, do all the LEDs start cycling though colors? I'm pretty sure that's the default behavior. And when you start the SimpleLEDTest app, do all the LEDs turn off except for port number one? With the test app, can you control any of the ports (on/off/intensity)? If the answer is no to any of these questions then it's possible the hardware is wired incorrectly or maybe even defective. There's also a possibility that the firmware has changed in some way so that LEDBlinky no longer works (with the hardware), but that would be very unlikely as others would have reported the same problem. Have you tried contacting Andy?
« Last Edit: November 15, 2016, 08:12:56 am by arzoo »
Robots will kill you.
Arcade Addiction
Poldilein
  • Last login:February 20, 2017, 06:50:30 pm
« Reply #8 on: January 04, 2017, 11:43:10 am »
Hi
I have  The ultimate io and ledblinky its not so easy but this Worms perfekt in Hyperspin.
Have 2 Joysticks and 8 Buttons Player 1 and 8 dir Player 2
Lg Poldilein
