Author Topic: forcing TV momentary switch to ON.  (Read 1832 times)
KapnKerfuffle
  • Last login:November 23, 2016, 11:48:14 pm
« on: October 24, 2016, 07:05:29 pm »
I would like to do the whole power up routine using a smart strip which will power on the monitor when the master power is engaged.  My searching is failing.  I have a cheapo TV with a momentary switch.  I've tried just holding the button down as the system boots up, but that doesn't work, so I won't be able to simply force the button in mechanically.  What are the basics for getting a TV to come on when power is present in the cord?  I haven't taken a crack at opening it up yet so I don't have any pics of the electronic guts.
Think the Unthinkable, Know the Unknowable,
Screw the Inscrutable and Eff the Ineffable.
  • Last login:Today at 02:30:40 pm
Re: forcing TV momentary switch to ON.
« Reply #1 on: October 24, 2016, 08:00:28 pm »
If you can get to the power button contacts, you can use a pushbutton or a relay.
take a look at this link, these guys used a 8.00 relay....
http://www.vpforums.org/index.php?showtopic=27987&hl=%2012v%20%20relay%20%20cycle%20%20timer
If you can't access the power button connections, use an IR transmitter like one of these . . .
USB Infrared Toy
Here is a post from back in March where a member got the USB Infrared Toy working on that exact brand of TV:
http://forum.arcadecontrols.com/index.php/topic,150198.msg1569076.html#msg1569076
. . . or one of these.
Solution # 2
https://www.amazon.com/gp/product/B018VKBGVC/ref=oh_aui_detailpage_o05_s00?ie=UTF8&psc=1
KapnKerfuffle
« Reply #2 on: October 26, 2016, 01:04:52 pm »
Thanks Scott.  This gives me some options.  Maybe the relay could be timed to bypass the TV's splash screen and the POST test text too.
