Author Topic: Mounting the Sanwa JLF without a mounting plate  (Read 2222 times)
Swevicus
  • Last login:July 07, 2024, 09:22:01 pm
« on: October 16, 2016, 05:33:04 pm »
Dear BYOAC,
Can the Sanwa JLF joystick be mounted into a control panel or an enclosure (ABS, aluminium) without the flat mounting plate (so I'm talking about the JLF-TP-8Y/8Y-SK), or do I NEED the flat mounting plate to actually mount the joystick in whatever panel/box I want to use?
Yours sincerely,
Swevicus.
kowal
  • Last login:September 17, 2023, 02:02:16 am
  • Suzo 4ever
Re: Mounting the Sanwa JLF without a mounting plate
« Reply #1 on: October 16, 2016, 05:52:42 pm »
you do not need MP
JLF body still have 2 tabs for screw M4
http://kowal.itcom.pl/foto/modDCAS-13.jpg
http://kowal.itcom.pl/foto/modDCAS-14.jpg
http://kowal.itcom.pl/foto/modDCAS-15.jpg
next method is 4 original hole and M3 screw the same how use mounting plate
buy M3 screw 6mm and all will be fine
next it is more invasive (I do not recommend) and powerful but uses a very old installation asymmetrical distribution of the 4 screws. basically is archetype but you can use it
http://kowal.itcom.pl/foto/modHSC4EX-04.jpg
http://kowal.itcom.pl/foto/modHSC4EX-14.jpg
Swevicus
« Reply #2 on: October 16, 2016, 06:25:36 pm »
Holy smeg! That's awesome! That means I could save a LOT of space! Thanks, man! :)
« Last Edit: October 16, 2016, 06:49:37 pm by Swevicus »
