Author Topic: Replacing graphic on coin plate  (Read 2924 times)
dylaninwv
  • Last login:October 09, 2019, 07:05:47 pm
« on: October 12, 2016, 12:39:17 pm »
Please see the below pic. I am looking to replace the graphics on this coin plate. I can do the artwork easy enough, but it there some kind of adhesive vinyl, or decal, or some special kind of decal paper I cna buy to print it out? Or is there a vendor that can print it for me? I am looking for something that will adhere to the metal and be durable. I assume it was originally silkcreened somehow?
  • Last login:March 16, 2026, 03:44:11 pm
Re: Replacing graphic on coin plate
« Reply #1 on: October 19, 2016, 12:04:33 pm »
if you want to DIY, you can do a b/w version fairly easily...
http://www.instructables.com/id/How-to-etch-aluminum-panel-labelsdesigns-with-a-r/
there was corybee here doing some custom serial plates... maybe give him a PM or something.
http://forum.arcadecontrols.com/index.php?topic=131720.0
otherwise you are looking at making and silkscreening your own. not impossible, but certainly a pile of effort. be okay for a small run, but not really a one off.
lastly... maybe go to staples and pick up some clear label material and print it out. then you can apply it and lacquer it on.
dylaninwv
« Reply #2 on: October 25, 2016, 10:02:32 am »
Thanks lilshawn! I'm going to try Pnp-blue. I've acid etched in college - I had no idea I could do a laser printer. Cool!
Monkeyvoodoo
  • Last login:November 16, 2024, 01:36:41 am
  • I swear I can stop at one. Or two.
    • threefoldhorse Custom
« Reply #3 on: November 20, 2016, 01:50:57 am »
It may be a little late but you could try custom trophy shops. I know the one near me can do multicolour metal plates
