Author Topic: Newbie question- ONE Button turn on for EVERYTHING (lights, computer, screen)  (Read 2633 times)
80sarcadegames
  • Last login:October 01, 2025, 09:41:51 am
I know that they have power strips that are "smart" that help with this goal, but how do
you set up your arcade cabinet if you want everything to turn on with ONE button.
By everything I mean:
1. Marquee/LED lights
2. Computer
3. LED control panel buttons
4. Screen
5. Electronic coin box
The screen question is the most perplexing to me. I'm not going to use a CRT that "automatically turns on when you plug the power cord into
the wall ie not power button on it". I'm using a LCD 27" computer monitor that has a power button on it (ie when you plug the power cable into an outlet, it does not turn on until you turn on the power button/switch on the monitor).
I know that you can change the CMOS on some computers that automatically turns on/off the LCD monitor when the computer is turned on.
Are there any other solutions if your computer does not have that option?
Titchgamer
1) will turn on with the power if plugged into a power strip
2) you can run the power switch of the PC through a relay that simulates you pressing the button (has to energise and de-energise quickly)
You can also get a computer PSU to energise straight away on power up by shorting 2 of the connections on the mobo connector.
But I dont think this would be practical for use with a pc (never tried it)
3) depends how they are connected, if using a pacled or similar board they will come on with the PC
4) if unable to start with the PC use the same option as 2.
5) again depends how its wired but again may come on with the pc if you use the pc psu.
Personally though I prefer to have a power button external (under my cp in my case)
So you can power on/off the pc separately.
  • Last login:Today at 02:42:24 pm
Just to be clear, have you tried:
1. Doing the power-on un-plug/re-plug test?
-- Plug in the montor.
-- Turn the monitor on.
-- Un-plug the monitor.
-- Wait a bit then plug in the monitor again.
-- If it comes back on without pressing the power button, the monitor will work in a slave socket of a smart strip.   ;D
2. Checking the LCD menus and owners/service manual to see if there is a "power restore" option. (may be worded differently)
2. Computer
4. Screen
2 and 4 both need an AC outlet.
Do 1, 3, and 5 need an AC outlet, or are any of them powered by the computer PSU?
