Author Topic: How to hook this up?  (Read 7822 times)
Haloman800
  • Last login:February 07, 2020, 12:40:00 am
  • Awfully Awesome
« on: October 05, 2016, 09:34:24 am »
I have my desktop, monitors, fan, etc. All hooked up to a squid. I wanted to hook it up to a single power switch, so I bought this:
However, the back isn't a normal outlet, it's this:
I don't even know what this is. Is there a converter I can get or what do I do?
Sent from my SM-N920V using Tapatalk
Slippyblade
Re: How to hook this up?
« Reply #1 on: October 05, 2016, 11:00:42 am »
Nope, it's just terminals that you solder your wires to.  There are some diagrams for this exact switch somewhere on the board though.  I'm at work right now or I'd go digging - probably on the wiki though.
« Reply #2 on: October 05, 2016, 11:07:20 am »
Search The Little Ms Pac-Man thread. There should be a photo in there.
« Reply #3 on: October 05, 2016, 03:15:58 pm »
The new wiki page is still down, but wayback machine was able to bring it up:
https://web.archive.org/web/20141104034659/http://newwiki.arcadecontrols.com/index.php?title=Wiring
Check under the section that says, "4-Tab Switch".  Pics below from the wiki.
DeL
05SRT4
  • Check out my Pow Pow
« Reply #4 on: October 05, 2016, 06:57:16 pm »
Did yours come with a fuse? I know some don't so double check.
Unstupid
« Reply #5 on: October 05, 2016, 08:46:53 pm »
here, in case the other photo was unclear:
  • Last login:Today at 02:32:05 pm
« Reply #6 on: October 05, 2016, 11:34:13 pm »
Nice photo, Unstupid.   :cheers:
Mind if I add it to the wiki when Saint gets it running again?
Unstupid
« Reply #7 on: October 06, 2016, 02:09:19 am »
Fine by me.
« Reply #8 on: October 06, 2016, 02:44:21 am »
Fine by me.
Thanks.   ;D
Haloman800
  • Awfully Awesome
« Reply #9 on: October 06, 2016, 09:38:52 am »
So I need to cut the power strip and connect these individual wires to their respected sockets?
What are the pink things that hold it together called?
Titchgamer
« Reply #10 on: October 06, 2016, 09:47:01 am »
The things on the end of the wires are female spade crimps or quick disconnects.
« Reply #11 on: October 06, 2016, 10:44:33 am »
Yes, cut off the wall plug and crimp on 1/4" (0.250") female Quick Disconnects. (QDs)
If you have un-insulated QDs like the ones in Unstupid's picture, consider using heat shrink to minimize the chance of accidental electrocution.
Make sure you have both good mechanical connections (QDs won't twist free) and good electrical connections (<2 ohms) BEFORE you try to run power through it.
Why is it important to have clean, corrosion-free, mechanically-solid and low-resistance power connections?
Badmouth shows why here and here.
P.S. Just noticed that your power switch is turned 180 degrees compared to Unstupid's and the example in the wiki.
The narrower-spaced tabs A and C are the input side.
The wider-spaced tabs B and D are the output side, where the lamp is.
If you use tabs B and D as the input side the lamp will be on whether the switch is open or closed.
« Last Edit: October 06, 2016, 11:11:21 am by PL1 »
Haloman800
  • Awfully Awesome
« Reply #12 on: October 06, 2016, 11:28:14 am »
This arcade is for my parents (dual screen cocktail machine, I'll be making a video of it soon, almost completed) and I don't want to burn their home down, so instead I got pic related from Amazon for a few dollars, used a black sharpie and colored it in.
I know it's a kind of cheating, but it looks good and I don't have to trust my wiring skills
Amazon link: https://www.amazon.com/gp/aw/d/B01M07MJGF/ref=mp_s_a_1_1?ie=UTF8&qid=1475767615&sr=8-1&pi=SY200_QL40&keywords=Power%2Bswitch&dpPl=1&dpID=41C9mhLvKgL&ref=plSrch&th=1&psc=1
thomas_surles
« Reply #13 on: October 17, 2016, 12:08:49 pm »
I was planning on using this thread to wire mine but the back of mine is short a pin. Any suggestions?
« Reply #14 on: October 17, 2016, 12:54:27 pm »
Looks like mine, hope these pix from Alpha-Too help:
Black is (H)ot or (L)ive
(N)eutral is White
(G)round or Earth Ground(EG) is Green
« Last Edit: October 17, 2016, 01:36:13 pm by Malenko »
Automark
  • Arcade in Spain ?
« Reply #15 on: October 17, 2016, 03:31:54 pm »
Alway use a multimeter (on continuity) to test it.
« Reply #16 on: October 17, 2016, 03:39:05 pm »
Use the 3-Tab Switch wiring directions.
https://web.archive.org/web/20141104034659/http://newwiki.arcadecontrols.com/index.php?title=Wiring#3-Tab_Switch
« Reply #17 on: October 17, 2016, 03:55:05 pm »
His plug wires are clearly labeled on the back.
thomas_surles
« Reply #18 on: October 17, 2016, 04:16:49 pm »
Ok so does this look right?
« Reply #19 on: October 17, 2016, 04:33:59 pm »
Yes, assuming that the on/off part of the switch (tabs 7 and 8 ) are the upper left in your pic.
Just to be sure, verify with your multimeter that you have continuity when the switch is on and an open when it is off.
thomas_surles
« Reply #20 on: October 17, 2016, 04:52:33 pm »
Alright thanks for the help guys. I will post pics of my house burning down on Friday. If not I might just update my build thread then.
« Reply #21 on: October 17, 2016, 06:49:34 pm »
To avoid that scenario, here is some rough-draft text that I'm planning on adding to the wiki once it is back in action.
Power wiring safety checks
It is important to have clean, corrosion-free, mechanically-solid and low-resistance power connections.
Make sure you have both good mechanical connections (QDs won't twist free) and good electrical connections (<2 ohms) on all three lines from the wall plug to the power strip outlets BEFORE you try to run power through it.
Remember to only measure resistance (ohms) when power is disconnected from the circuit or you will damage your multi-meter.
If only a few strands of the power cable are making contact with the terminal, the connection will still ohm out OK, but those strands will have to carry the entire electrical load over that narrow connection.
This can lead to a vicious cycle where the current flowing through that narrow connection generates heat which causes the wire to corrode which increases the connection resistance which generates more heat . . .
thomas_surles
« Reply #22 on: October 21, 2016, 01:49:45 pm »
The good news is my house didn't burn down. The bad news, I updated my build thread...
For closure I here are the pics.
Haloman800
  • Awfully Awesome
« Reply #23 on: October 27, 2016, 06:43:01 pm »
Unrelated, but where did you get the speaker mesh covering at?
thomas_surles
« Reply #24 on: October 27, 2016, 07:45:40 pm »
I never mentioned it in my build log but is pulled them off some house speakers from a record player and cut them with some tin snips.
roknrol
  • Last login:October 30, 2025, 03:51:17 pm
« Reply #25 on: November 01, 2016, 06:40:17 pm »
Related ;D, where did you find the blue rocker switch? I've only run across the red or green variety.
thomas_surles
« Reply #26 on: November 01, 2016, 07:31:12 pm »
Ebay. It's the only one I saw. There may be more. What they don't tell you is that the led is orange, so that's kinda lame.
roknrol
« Reply #27 on: November 02, 2016, 05:04:51 pm »
Meh, yeah that wouldn't work. Thanks for the reply and the heads up!
thomas_surles
« Reply #28 on: November 02, 2016, 09:39:04 pm »
Yeah this is what it looks like little up.
roknrol
« Reply #29 on: November 03, 2016, 10:24:46 pm »
Blech. You're right -- lame.
Where's that barfing emoji Scott loves to use so much ...?
« Reply #30 on: November 04, 2016, 07:32:50 am »
Click on "[more]" under the emojis -- it's between :bump and  :droid.
or just type in
:puke
