Author Topic: sequential shifting on sega model 2?  (Read 15230 times)
rushfanyyz
  • Last login:October 12, 2016, 11:14:36 am
« on: October 05, 2016, 01:38:51 am »
hi guys, i'm wondering if this is possible? works fine in supermodel but can't seem to make it happen in m2 (no option that i see to do it)  i'd love to be able to play daytona using manual
brad808
Re: sequential shifting on sega model 2?
« Reply #1 on: October 05, 2016, 02:22:42 am »
Yeah you need an extra little program to do it. Forget the name exactly. Something like h2seq?
vandale
  • Id 10 and t error
rushfanyyz
« Reply #3 on: October 05, 2016, 09:21:00 pm »
right on, thank you!  have you used this before on your setup?
Boomslang
« Reply #4 on: October 05, 2016, 09:25:59 pm »
yeah Ive used it before. works well
rushfanyyz
« Reply #5 on: October 05, 2016, 11:07:43 pm »
awesome, i'm looking at it, i'm not sure how to install it, could you offer any tips on that?
buttersoft
  • Last login:Yesterday at 06:13:33 pm
  • Is running at 15kHz
« Reply #6 on: October 06, 2016, 12:59:14 am »
Just run it, and leave it going.
Read the docs first to make sure you bind to the right options/button. I'm using Joytokey to bind my button presses to the up/down shift keys, and then I bound the actual gear keys to the emulator.
MTPPC
« Reply #7 on: October 06, 2016, 11:23:25 am »
I find sequential shifting to be more of a pain with MAME games with Hi/Lo shifter buttons. It acts more like an "other gear" button.
http://pinballmd.com/
  • Last login:Today at 11:22:52 am
« Reply #8 on: October 06, 2016, 11:45:01 am »
Read the MAME section of the NOOB thread stickied at the top of this forum.  :P
EDIT: I guess that doesn't help if you have a sequential shifter that returns to center.  :-\
« Last Edit: October 06, 2016, 11:51:23 am by BadMouth »
rushfanyyz
« Reply #9 on: October 06, 2016, 09:25:04 pm »
i set the shift buttons to the same thing i have in supermodel in the .ini but no luck.  i clicked the program before running model 2 but nothing seems to happen.  what am i missing?
MrThunderwing
  • Last login:August 19, 2025, 02:18:43 pm
« Reply #10 on: October 08, 2016, 07:53:20 am »
I don't get why people would want to sequential shift in Daytona USA (not a criticism, just an observation) - Isn't being able to shift instantly from 4th to 1st or 2nd pretty essential to the whole gear drifting experience? Neither of the two wheels I've got have got proper stick shifters (they both have sequential flippers), so I assign buttons on the front of the wheels to the individual gears. It seems to work pretty well, maybe it might be worth a try as an alternative?
buttersoft
« Reply #11 on: October 08, 2016, 09:11:19 pm »
I'm not sure English is your first language, but... have you read the documentation for H2seq? Do you understand what it's supposed to do? Are you sure you've bound your keys right?
Essentially - in your emulator you assign the four gear keys to what you want. Doesn't matter what - you won't actually be pressing them. Then in H2seq, you bind the four gears to those same keys, and after that bind the two keys you actually want to use for up-gear and down-gear to those inputs. You only actually press the last two.
Run H2seq first, make sure it's set to turn on with your emulator, then launch your emulator.
I find paddles to be a bit artificial for the way i like to play. I have a few older wheels set up with seats, and they have up-down stick shifts on the side. I like using the sticks as it makes things feel more arcadey. One day i might upgrade to FFB and h-shifters, but it'll cost a bomb.
rushfanyyz
« Reply #12 on: October 09, 2016, 12:20:45 pm »
help me, what am i doing wrong?  i don;t know how to set it to work with the emulator.  i click the program and it does nothing at all, but it did create the config file.  here's what is set, first in daytona, second and third in the config.  i'm sure there's something stupid i'm doing wrong and not understanding
buttersoft
« Reply #13 on: October 09, 2016, 06:38:28 pm »
I haven't looked at h2seq for a while, but... I'm pretty sure you can't bind joystick buttons directly in H2seq. It only takes the keys listed, using the codes listed. I have no idea if those are standard codes or ASCII or what.
You don't need to redo anything yet. From right where you are now, the next step is to try binding the gear up/down keys in h2seq cfg file to actual keyboard keys, using the codes provided. Say DD and DB for "[" and "]" - simply because I can see those codes in your screenshot. So instead of JOY1_BUTTON13 and JOY1_BUTTON14, you put DD and DB. Leave everything else in M2emulator and the H2seq cfg file as it is.
Now double-click the H2seq program, and check the taskbar cion down the bottom right to make sure it's running. Hover the mouse over icons to find out what they are. If H2seq is there, open m2emulator, open a game, and test the "[" and "]" keys while driving to see if they work.
If that works up to now, and you want to use joystick buttons instead of [ and ], look into Joytokey to bind those buttons to input [ and ] for you. Or, if you're already using something like UCR you can just use that, but it's pretty nasty to get into. Joytokey is easier.
« Last Edit: October 10, 2016, 01:27:43 am by buttersoft »
rushfanyyz
« Reply #14 on: October 09, 2016, 11:41:31 pm »
thanks man, i'm going to read this carefully again when i have time to mess around w the program again.  thanks for having a look!
rushfanyyz
« Reply #15 on: October 12, 2016, 11:15:32 am »
nothing.  how do i connect this program to the m2 emulator?
buttersoft
« Reply #16 on: October 12, 2016, 06:24:18 pm »
You don't connect it, you just run it first, making sure to leave the Active Emulators option for model2 set to "1" (in your screenshot above.) When H2Seq runs, it sits in your system tray with a black icon with a white H and tiny red gear knob. Can you see the icon in the system tray?
You are using M2emulator, yes? (it works with the  multi_cpu exe or the standard exe)
isamu
  • Last login:August 14, 2025, 08:21:54 pm
« Reply #17 on: October 13, 2016, 07:19:39 am »
Interesting little tool.
I'm actually looking for something that does the OPPOSITE of this. I want to be able to use my H-Pattern shifter in games that support *only* sequential shifting. Something like what Howard used to allow us to shift directly to any gear we want without having to go through each gear one by one.
Howard if you're reading this....is it possible to make a break-out app that mimics the behavior of whatever you used to accomplish this option in OR2C2C? This would be great for the Ridge Racer console games!
  • Last login:Yesterday at 11:11:41 pm
« Reply #18 on: October 13, 2016, 02:05:40 pm »
It's possible, but it isn't easy.  The memory location of the current gear has to be found for any game/emulator in question and the location needs to be writeable so I can write back to it.  In addition some games require code to be removed/no-OPed before the gear shift can be controlled externally.
jorgenjl2
  • Last login:October 07, 2025, 07:20:28 pm
« Reply #19 on: November 18, 2023, 12:02:33 am »
H2Seq works great for me. The issue is that once you are in 4th gear, if you restart the game, you are stuck in 4th gear. Even though it shows you are in first gear, you have to remember to hit downshift 4 times. Anyone know a workaround? I tried setting up a ahk file to send four down shift keystrokes to Mame (or even better the “i” key corresponding to first gear) and it works in notepad but it never sends the downshift or 1st gear directly to Mame. I also tried Powershell and same thing. I think h2seq only works with Mame and model 2 based on the confit file setting. Manually hitting downshift four times (or “i”) as soon as the Mame game starts does work but family and friends will not know to do that before every race. Thoughts?
« Last Edit: November 18, 2023, 12:04:42 am by jorgenjl2 »
buttersoft
« Reply #20 on: November 18, 2023, 02:43:24 am »
Boomslangnz's FFB plugin has the control options for m2emu to make H2seq obsolete. Might be worth a shot. You won't need the FFB if you don't have the wheel for it, of course, but it should still work...
jorgenjl2
« Reply #21 on: November 18, 2023, 11:56:55 pm »
Interesting I didn’t know that. Does it also work for Mame? I want to say Supermodel works already but I need to validate. I also wonder if setting keyboardprovider dinput instead of auto in the Mame.ini may fix the ahk command issue but I can test it tomorrow
buttersoft
« Reply #22 on: November 19, 2023, 03:37:22 pm »
I don't think so. I know Demul has inputs and so does M2 - i think Boom chose games that had big input problems to focus on and fix, but i have no idea if he's planning to expand to more games.
What were you meaning about Supermodel?
It did for me. Well, if you mean that AHK keypresses weren't seen in mame before that change, yes, it did :) From memory though, i also had to set a 50-100ms keypress time for some games, as presses of zero duration often didn't register.
« Last Edit: November 19, 2023, 08:11:56 pm by buttersoft »
niblettr
  • Last login:December 29, 2024, 08:57:29 am
« Reply #23 on: December 29, 2024, 07:17:34 am »
I have yet to get sequential shifting working on Model2 (Sega Rally)
I'm using an Xbox one controller which works for everything (except gear shifting)
here are my settings (left as default except setting joystick = 1)
joystick = 1
first = i
second = k
third = o
fourth = l
clutch = SPACE
;KEYBOARD Key should only be used once
gearup = 28 ;28 = DOWN ARROW KEYBOARD key - GUESS NOT USED IN THIS INSTANCE
geardown = 26  ;26 = UP ARROW KEYBOARD key - GUESS NOT USED IN THIS INSTANCE
view = 5A
[joy_assign]
; Define here the two joy buttons you want to use for sequential shifting.
; Use the joystick_Test script to identify the number associated to your joystick button.
joy gearup = 16 ;16 = LEFT TRIGGER joypad (confirmed by Joystick_Test tool) THIS DOESN'T SEEM TO WORK!
joy geardown = 32 ;32 =  LEFT TRIGGER joypad (confirmed by Joystick_Test tool) THIS DOESN'T SEEM TO WORK!
joy view = 2
joy exit = 10
[emulators]
; active emulators
model2 = 1
mame = 1
supermodel = 1
On the model2/sega rally side, mapping is as follows>>
Shift 1 I
Shift 2 K
Shift 3 O
Shift 4 L
This is all I need as far as I'm aware but can't get this work!
Please, someone help? would be great to debug this without using the model2 emaltor first (eg. setting shift key strokes to notepad first or something.
EDIT, just realised I need to use this in conjunction with joytokey. (what a mess) I did try, still stuck.
« Last Edit: December 29, 2024, 08:09:14 am by niblettr »
niblettr
« Reply #24 on: December 29, 2024, 08:30:27 am »
so, will both utilities running, I get key A and key Q (I moved away from up down as it's hard to debug and helps nobody) presses appearing in notepad (due to joytokey working)
My guess is h2seq captures these A and Q pressed (originating from trigger buttons on my controller) and spoofs out the corresponding I or K or O or L shifts setup in model 2 emulator. If I am correct, h2seq seems to be doing noting!
buttersoft
« Reply #25 on: January 08, 2025, 11:05:54 pm »
Hmm, you might try BoomdlangNZ's FFB plugin. I think that will let you enable sequential shifting without needing to run H2Seq. Which i did have running correctly once but it's been so long i can't remember anything. The M2emu is a bit shifty when it comes to how it captures devices, but the FFB plugin can help fix that.
Noctourniquet
  • Last login:January 14, 2025, 04:06:53 pm
  • i wish i'd never gotten into this hobby
    • Personal Neocities Site
« Reply #26 on: January 12, 2025, 01:59:48 am »
okay i created an account here for the sole reason of attempting to ask for help in this thread since it really is the only resource available for this stuff (especially now since the h2seq website seems to be down for the count), but after fiddling with h2seq for another hour i figured out how to get the program working on m2emu with my driving force GT, and since i'm already here + maybe someone out there is in my exact same situation, i want to just get my setup out there. i didn't try the FFB plugin mentioned here as i had no clue how a teknoparrot FFB plugin would allow me to use sequential shifting in a model 2 emulator, but maybe i'm screwing something up in that regard or missing something obvious.
h2seq absolutely hates my DFGT. neither the joystick test nor the program itself ever recognized the standalone wheel, for some reason. it wouldn't even let me use joy2key, which makes no damn sense because i could use my down/up arrows to shift in-game, but i couldn't use the sequential shifter which was mapped to said down/up arrows to do anything, even with joy2key itself recognizing my inputs. but for some god forsaken reason, having an xbox 360 pad connected allows me to use my joy2key setup just fine (this is using the stock microsoft drivers for the 360 pad).
so, to sum it up: kept all of the settings in the config.ini completely stock. used joy2key to bind my seq shifter to the down/up arrows respectively, then in m2emu did all the usual setup, binded everything except the gears which were set to the stock IKOL binds, and as long as i have an xbox 360 controller connected to my PC, it seems to work well. sucks that somehow, i need to have AA batteries on standby to play daytona USA of all games.
i've been fiddling with this crap for what feels like ages, both today and a few months ago when i couldn't figure it out. i hate this stupid hobby  :banghead:
buttersoft
« Reply #27 on: January 21, 2025, 06:54:05 am »
BoomslangNZ's FFB plugin may have started for Teknoparrot, but it does several emulators now. MAME, flycast, and, wait for iiiiiittt... M2emu. It also circumvents some quirks in the emulator, and allows you to bind all your keys/buttons/axes without needing to open the M2 emulator itself. So yes, it is definitely worth looking at first if you are having probs. Or possibly even if you aren't.
Another thing to try is opening all programs at the admin level, emulator, J2key, AHK, RTSS, etc. Sometimes Joy-to-key won't pass keys along unless it has higher permissions. And the emulator probably wants to be on the same level to see them, etc.
