Author Topic: High Score Competition #201: Bongo  (Read 11639 times)
ninjabadger81
  • Last login:September 20, 2018, 01:04:52 pm
« on: September 26, 2016, 07:39:31 am »
Game Name : Bongo (1983, Jetsoft)
ROM Name  = "bongo"
Settings:
   default : Lives -3
Controls:
    Joystick: 8-way joystick
Bongo, Jetsoft 1983
Not too much info on this one:
An early platform game.
You play on the role of a hilarious tourist trapped in a cave and chased by a red dinosaur, you have to jump through different rock platforms and elude the lava, falling objects and the animals to pick six bonus objects without losing a life, as you advance in level you get to higher difficult areas where find and follow the caveman path to exit the cave alive, but before you must use an old cage to trap the annoying dinosaur.
This game is pretty bad, but it's so bad it's actually good and very addictive trying to beat the high score (which seems good for this competition).
Sorry if I have done this wrong (be gentle it is my first time).
Good luck!
Final scores.
1st:  Yamatetsu - 275,150
2nd: JDFan - 202,250
3rd: JFitziner - 159480
4th: Ninjabadger - 90,400
5th: Titchgamer - 73,790
6th: pbj - 17,770
7th:  Mike A - 14,110
Last day: Sunday, October 9 2016 midnight Pacific
- Quest for the Bronze Joystick! The most successful competitor of each calendar year will possess & display the BYOAC Bronze Joystick Trophy. See this thread for details: The BYOAC Bronze Joystick.
Happy Gaming!
« Last Edit: October 10, 2016, 07:46:37 am by ninjabadger81 »
  • Last login:Today at 07:47:22 am
Re: High Score Competition #201: Bongo
« Reply #1 on: September 26, 2016, 10:11:02 pm »
Here is my first try. This game is lametastic. ;)
ninjabadger81
« Reply #2 on: September 27, 2016, 04:50:26 am »
20,330 to get things going :-)
« Last Edit: September 27, 2016, 04:52:51 am by ninjabadger81 »
yamatetsu
  • Last login:Today at 01:10:03 am
  • Just because.
« Reply #3 on: September 27, 2016, 10:43:11 am »
This could actually have been a decent game ... if the controls didn't suck ass. A jump button would have worked wonders.
  • Last login:Today at 05:10:51 am
« Reply #4 on: September 27, 2016, 12:32:56 pm »
Would it violate competition rules if you mapped jump to a button instead of the joystick?
Titchgamer
« Reply #5 on: September 27, 2016, 12:57:43 pm »
Well under controls it does only mention the stick so technically yes I would guess??
yamatetsu
  • Just because.
« Reply #6 on: September 27, 2016, 01:23:50 pm »
Since it's done to make the gameplay easier, the player doing that would have an unfair advantage. However ... If everyone would do it, it would be ok.
I have tried it, this really makes a difference. No more dying because the joystick didn't register the diagonal, no more accidental jumps because the stick did register a diagonal when it shouldn't have. This game needs a two-way stick and a jump button.
Oh, and just for the recrod :
110,190. Using the crappy controls.
« Last Edit: September 27, 2016, 01:25:56 pm by yamatetsu »
« Reply #7 on: September 27, 2016, 01:25:16 pm »
Some competitors used a joystick during last year's Space Zap comp.
Controls:
    5 buttons (Up, Down, Right, Left, Fire)
    Can easily be played with joystick as well.
Seems like the same thing but in the opposite direction.   :dunno
P.S. Using a jump button really does make the game better.  Thanks for bringing it up, Yamatetsu.   ;D
Titchgamer
« Reply #8 on: September 27, 2016, 01:35:28 pm »
Well ime happy using a button if everyone else is?
yamatetsu
  • Just because.
« Reply #9 on: September 27, 2016, 01:38:48 pm »
Controls:
Yup, that's the same thing. I remember not being able to play Space Zap using the buttons so I didn't play it at all. Using the stick would obviously have been much easier, so it would have been an advantage. In that particular game, you can argue that using the stick you probably will be slower at firing since it takes time from moving say, from left to right, whereas just pressing the button is much faster. But that's another story.
Nothing like having proper controls  ;D
yamatetsu
  • Just because.
« Reply #10 on: September 27, 2016, 01:40:12 pm »
I'm happy pressing buttons  :D
« Reply #11 on: September 27, 2016, 01:45:36 pm »
Motion proposed and seconded.
Is there anyone opposed to allowing use of a jump button in this competition?
JDFan
« Reply #12 on: September 27, 2016, 01:53:15 pm »
If playing on a keyboard it uses the arrow keys just like any other game would so don't see why it would be any different than remapping an arcade system to use a button layout you prefer. Or does that mean anyone on a PC can't play this game for the comp ? :dunno
yamatetsu
  • Just because.
« Reply #13 on: September 27, 2016, 02:17:59 pm »
If you use an input device (a button, for example) that was not used in the original game to make the game easier, you gain an advantage. So in this case yes, if you use a keyboard, you are using a more precise control method than the original game did.
But as far as I'm concerned, anyone using a keyboard already is at a disadvantage  :D
JDFan
« Reply #14 on: September 27, 2016, 02:26:26 pm »
Agreed - normally using the keyboard is a slight disadvantage but the PC is pretty much always on where the bartop needs to be turned on when playing - so depending on how much time I have to play will determine if it's played on one or the other (Since I've been playing PC games for Ages the keyboard controls are pretty much second nature at this point)
ninjabadger81
« Reply #15 on: September 28, 2016, 05:07:45 am »
I've got no problem with people remapping the jump button.
In fact, I'll be trying it myself later :-)
ninjabadger81
« Reply #16 on: September 28, 2016, 05:33:40 am »
90,400 (using keyboard)
ninjabadger81
« Reply #17 on: September 28, 2016, 05:48:28 am »
yamatetsu
  • Just because.
« Reply #18 on: September 28, 2016, 12:20:30 pm »
156,850. This is the interesting name that is bestowed onto you if your cheap chinese wireless xbox 360 adapter disconnects while you are trying to enter your name.
Titchgamer
« Reply #19 on: September 28, 2016, 12:32:55 pm »
Easy solution to that...
Dont use a girly controller :p
Titchgamer
« Reply #20 on: September 29, 2016, 09:23:41 am »
Finally had a chance to give this a quick go.
Fun game but the controls are terrible lol
ninjabadger81
« Reply #21 on: September 29, 2016, 11:34:11 am »
Standings so far
1st:  Yamatetsu - 156,850
2nd: Ninjabadger - 90,400
3rd: Titchgamer - 20,690
4th:  Mike A - 14,110
yamatetsu
  • Just because.
« Reply #22 on: September 30, 2016, 06:21:32 am »
Try using a girly controller.
171,900.
Titchgamer
« Reply #23 on: September 30, 2016, 06:22:31 am »
171,900.
Never!!
ninjabadger81
« Reply #24 on: September 30, 2016, 11:47:07 am »
Need to try to improve.  Want to see what happens at the end.
yamatetsu
  • Just because.
« Reply #25 on: September 30, 2016, 02:25:48 pm »
200,990. Died 3 times in level 26  :banghead:
ninjabadger
  • Last login:August 20, 2018, 12:31:03 pm
« Reply #26 on: September 30, 2016, 02:39:40 pm »
Is that the last level?
Sent from my SM-N910F using Tapatalk
yamatetsu
  • Just because.
« Reply #27 on: September 30, 2016, 03:03:43 pm »
It's the second lo last. I have made it to level 27, where you have to actually catch the dinosaur by jumping against a cage. If you mistime it, you die. I had of course just one life left to find that out.
yamatetsu
  • Just because.
« Reply #28 on: September 30, 2016, 06:12:56 pm »
Not a new high score, but THE END (?)
Mr. Dino has been captured, people are dancing (for quite a long time), suddenly Mr. Dino's twin brother appears ! Run, everybody, RUN !
Thus begins the second loop, which is a bit harder as everything is sped up.
  • Last login:Yesterday at 02:48:44 pm
« Reply #29 on: October 02, 2016, 09:17:19 pm »
 :soapbox:
« Last Edit: October 03, 2016, 09:38:03 am by pbj »
ninjabadger81
« Reply #30 on: October 03, 2016, 05:17:10 am »
Ha, brilliant.
Must try to get there myself!
yamatetsu
  • Just because.
« Reply #31 on: October 03, 2016, 10:09:10 am »
219,560.
ninjabadger81
« Reply #32 on: October 03, 2016, 11:49:41 am »
So far...
1st:  Yamatetsu - 219,560
4th: pbj - 17,770
5th:  Mike A - 14,110
JDFan
« Reply #33 on: October 03, 2016, 02:57:33 pm »
Got a chance to try a few games today -- the controls are terrible  :angry: but still a fun little game. 61,160
A few more tries and a bit of improvement  - then die 3 times on a single level  :angry:
110,320
« Last Edit: October 04, 2016, 03:08:00 pm by JDFan »
ninjabadger81
« Reply #34 on: October 05, 2016, 06:36:52 am »
Scores updated.
JDF try re-mapping jump to a button.
Titchgamer
« Reply #35 on: October 05, 2016, 08:15:15 am »
Ive got a bit further...
JDFan
« Reply #36 on: October 05, 2016, 10:08:48 am »
Scores updated.
THink this game is more a memorization of the level layout and timing - new levels take a few tries to get the movement through that screen timed out but it pretty much is just repitition once you get it worked out. ( The important thing is getting the bonuses for not dying between IIRC 6 bonus items picked up - as the bonus continues to increase another 10K each time it is completed - ie first bonus is 10K next 20K then 30K which adds to your score quite a bit ! ) So stringing together the 6 items without dying will make a big difference in the score.
Haloman800
  • Last login:February 07, 2020, 12:40:00 am
  • Awfully Awesome
« Reply #37 on: October 05, 2016, 10:46:57 am »
You must listen to this song while you play:
Sent from my SM-N920V using Tapatalk
j.fitzenr
  • Last login:August 28, 2018, 05:07:01 pm
  • Don't Afraid to be Great
« Reply #38 on: October 06, 2016, 07:30:51 pm »
This game ain't nearly as bad as I was expecting!
I think some-time in the early 80s a Roc'N'Rope ran off and had an affair with a copy of Smurf Rescue, and poof.  This thing.
Second try: 58k... I gotta figure out the hit detection on the bonus items and on the platforms you have to jump up sorta half-through...  blerg
EDIT: cracked 100k, this game is surprisingly fun.
Anybody figured out the game mechanics though?  From what I can tell from running the first screen over and over again, you seem to get points for more than just pickups and your X position like I thought at first.
I *believe* it has something to do with spending more time in the air, or at least leaving the screen in the air.  Hmm.  It seems like a small difference (~200 on the first screen is as high/low as I've gotten) but it could matter for some of you hardcore types!
« Last Edit: October 06, 2016, 08:10:34 pm by j.fitzenr »
ninjabadger81
« Reply #39 on: October 07, 2016, 04:33:09 am »
100k is a good score - get your screen print up and I'll put you on the table.
