Author Topic: arcadeos, arcade monitor, slanted picture  (Read 3653 times)
neuromancer
  • Last login:May 10, 2006, 04:26:57 pm
  • Can I Play?
« on: June 17, 2002, 07:43:57 am »
OK,
When ArcadeOS is running, the picture on my arcade monitor is basically what I would expect. When I start a game in vantage, the picture is skewed. A line on the bottom of the (vertical) screen slants from lower left up at about a 45 degree angle.
When I start a game in MAME it is slanted too, but I also get multiple copies of it on the screen. In either case when I go back to Arcadeos I get a good picture again.
There is another issue (maybe unrelated) every once in a while, the left side of the screen "splits". A horizontal line becomes a >.
This effect only lasts several seconds. I'm thinking that might be a problem with the horizontal synch.
Technical details: Jaton video card with trident chipset. I used a VGA cable with 5 BNC connectors. I took the H and the V wire and twisted them together and connected them to the synch wire on the monitor.
Any ideas?
Bob
South Carolina
« Last Edit: December 31, 1969, 07:00:00 pm by 1026619200 »
jimmyjames
  • Last login:September 02, 2002, 02:19:54 pm
Re:arcadeos, arcade monitor, slanted picture
« Reply #1 on: September 02, 2002, 02:37:04 pm »
Did you ever fix this problem - i have the same thing going on with my trident 9750 and electrohome g07-cbo? I dying to find out!
Thanks.
BobA
  • What Me Worry?
« Reply #2 on: September 02, 2002, 09:05:36 pm »
Try fraggal's CD for a new arcadeos and advance mame.
http://mame.how.to/
BobA
