Author Topic: FPGA based dumb frame buffer - Why has this not been created?  (Read 21945 times)
emubastard
  • Last login:October 18, 2018, 07:10:57 pm
  • I met your mom once, she looked like Ms. PacMan!
    • Emubastard
« on: September 13, 2016, 01:30:19 pm »
With all the old consoles receiving open source scan converters, and RGB conversion boards.... I thought...
Instead of hacking the ---steaming pile of meadow muffin--- out of mame and ATI drivers.
Wouldn't it be easy for someone to create a dumb framebuffer USB 2.0/3.0 device to connect to an RGB device?  Would the latency be low enough?
Just bypass the whole windows display chain completely and have a real/fake FPGA framebuffer to do whatever you want with.  Then it works with any video cards since it's actually not using the primary display device at all.
God knows i wish I could do this, I'm just surprised with the amount of FPGA flash carts, AD Converters and other FPGA projects that no one has created something like this for mame.
Just a thought... Maybe if such a device existed, developing groovymame would be easier.
Windows & Linux via USB, seems like a lot of good could come from a device like this.  People seem to pay a lot for all the other neat FPGA devices out there that do various kinds of frame-buffer output.
Imagine, a plug and play mame frame-buffer RGB output device...
Just kinda seems like endleslly hacking windows 7, 10, what ever is next.... why not just make a framebuffer device.
-James
-Bastard
  • Last login:March 15, 2026, 04:39:26 pm
Re: FPGA based dumb frame buffer - Why has this not been created?
« Reply #1 on: September 13, 2016, 04:52:22 pm »
Admittedly I have envisioned such device since long, although creating it is completely beyond my knowledge and skills.
The USB port would probably be a limitation. I had imagined something more like a pci-express board.
One possible design would simply mirror the gpu framebuffer ram and implement the logic to perform DAC based on user defined timings, totally bypassing the OS. The hardware implementation would implement a CRTC. Switching video modes would be as simple as sending the new CRTC values (modeline) to the device, taking effect instantly, without the insane overhead that mode switching involves on modern operating systems.
Another more ambitious design would involve the emulation of the whole CRTC itself, and just implement one DAC for each line (R, G, B, H, V). This would work without any video card on the system. The hardware implementation would be more simple, but the RGB-HV signal would need to be created by software on real time. I think the CPU requirements would make this approach impossible. This design would virtually allow to recreate any video signal that ever existed. An emulator supporting this wouldn't even require to do any v-sync.
The paradox is the hardware to do this is already invented inside any cheap video card available, it's just a software issue.
« Last Edit: September 13, 2016, 04:55:16 pm by Calamity »
emubastard
    • Emubastard
« Reply #2 on: September 13, 2016, 05:08:05 pm »
Well then.... is USB 3.0 latency too much of an issue?
I thought.... why not see if existing hardware can be hacked, USB is an open protocol, maybe one of these devices could be... re purposed to a dumb frame buffer and not a video card at all.
Such USB 3.0 hardware exists, and it's cheap... if only it could be repurposed.... maybe some of these use FPGA's.  I'm sure someone with the skills could crack one of these devices for exactly your needs.   No hardware creation needed.  Just some clever software engineer.
https://www.google.com/search?q=USB+3.0+to+vga&espvd=2&source=univ&tbm=shop&tbo=u&sa=X&ved=0ahUKEwiBtuD9no3PAhVHzmMKHTETB7sQsxgIHg&biw=1431&bih=864
-Bastard
emubastard
    • Emubastard
« Reply #3 on: September 13, 2016, 05:13:44 pm »
And then there's another thought.  These USB 3.0 to VGA adapters must not use increadibly complex software, say compared to AMD drivers.
Maybe one of these devices drivers would be easier to hack for custom resolutions.  We all keep our high powered video accelerated main card and just plug one of these little guys in with some hacked driver software to do what your doing now in CrtEmu Drivers.
Assuming USB 3.0 latency doesn't limit anything I've suggested so far....
-Bastard
« Reply #4 on: September 13, 2016, 06:23:30 pm »
Leaving USB speed apart, those USB cards are recognized just like normal video cards by the OS, so there's probably no much advantage over what we're doing now.
« Last Edit: September 13, 2016, 06:26:24 pm by Calamity »
elvis
  • penguin poker
    • StickFreaks
« Reply #5 on: September 18, 2016, 08:58:09 am »
I've often wondered why simple "line-halvers" don't exist.
There seems to be an abundance of cheap VGA to CGA converters on eBay (~$50 price range), but every single one of them produce an interlaced 480i output.  It's a shame nobody's made one that produces a 240p output instead.  These would be fantastic for indie games and emulators already upscaling lower resolution content anyway, and a simple physical switch could be used to decided whether even or odd lines are discarded.
AstroFan
  • Last login:March 17, 2026, 03:04:09 pm
« Reply #6 on: September 20, 2016, 04:32:49 pm »
It's not FPGA based but ARVID does some of the things you want.
http://mujweb.cz/molej/arvid/
ufoufo512
  • Last login:September 22, 2016, 02:09:41 pm
« Reply #7 on: September 22, 2016, 10:15:27 am »
Arvid seems awesome and clever project! Probably need to make one. I hope the project will go on (not that I quickly see anything missing in its current form), just hope it reaches people who think it is cool. I hadn't heard anything about it previously.
ufoufo512
« Reply #8 on: September 22, 2016, 10:27:15 am »
There are also ready made pcb boards (without component available) at http://dirtypcbs.com/view.php?share=12822&accesskey=5a73f683ece0249a8034b7781067ea21 . If I understand correctly 10 pieces cost 25 dollars including shipping which is very cheap imo. Only problem is: what do I do with 10 boards :) On top of that you need Beaglebone mini computer and some basic components. Looks ideal hobby project.
emubastard
    • Emubastard
« Reply #9 on: September 22, 2016, 12:15:19 pm »
"100 MBit ethernet interface for communication with the host PC"
Sounds like LAG to me.
Whatever it is, it seems reasonable that it would have to connect to PCI-E to match the performance level of Calamities existing solution.
USB 2 and 3 look like they would add at least one frame of lag (if not more).
Someone feel free to correct me.  These are some assumptions based on a little googling of the specs.
-Bastard
ufoufo512
« Reply #10 on: September 22, 2016, 01:41:33 pm »
I thought about lag too first. In the Youtube video author says he is using crossover cable and with that latency is around half of a millisecond, so it is non-existent. I have no first hand experience but I am tempted to try it out.
Doozer
  • Z80 ERROR
« Reply #11 on: September 23, 2016, 03:59:56 am »
I can confirm that USB or Ethernet based solutions would not introduce more than 1ms of delay for the communication layer.
The picture construction and video synchronisation could add 1 buffer delay to the picture (20ms). Direct rendering is subject to clock synchronisation between the transmitter and renderer.
Nevertheless, ARVID is a very promising solution. I am wondering if an USB CPLD development stick could provide the necessary IO to drive a CRT. (i.e. http://www.icstation.com/epm1270t144-50mhz-cpld-development-board-core-board-module-jtagusbswitchkeyprotection-p-9122.html or http://www.icstation.com/50mhz-max3000-cpld-development-board-core-board-module-jtagusbledldo-p-9121.html)
pakoman
  • Last login:November 05, 2024, 08:36:26 am
« Reply #12 on: September 23, 2016, 07:58:51 am »
Looks really promising as an universal solution. I assume it needs the emulator to be modified to be compatible with arvid.
AstroFan
« Reply #13 on: September 23, 2016, 02:19:11 pm »
There are a few devices that do that, for example MIMO's Genius box II. http://retrogaming.hazard-city.de/mimo.html
Besides Arvid, I remember reading about some FPGA/CPLD based framebuffer solutions that may be interesting or useful as a codebase:
ELM's General purpose display controller  http://elm-chan.org/works/crtc/report.html
And Project VGA's open source VGA video card http://wacco.mveas.com/
olin
  • Last login:June 30, 2018, 01:54:44 pm
« Reply #14 on: October 08, 2016, 02:43:34 pm »
I've just released arvidmame0163r3 for ARVID. Works well enough for me.
... Only problem is: what do I do with 10 boards :) On top of that you need Beaglebone mini computer and some basic components. Looks ideal hobby project.
I have 2 spare boards (soldered and working) sitting on my desk. If you live in Europe then PM me and I'll send you one. It applies for the second one as well - if anybody wants to try it let me know.
Edit: I also have extra 3 unpopulated boards I'm happy to give away. Somebody with an arcade monitor that is not afraid to experiment/try-it-out would be handy as well.
Related to FPGA and USB.
That was the original idea behind ARVID. Unfortunately when I started (2 years ago) I could not find cheap dev board that has FPGA, SRAM and USB 2.0 interface on a single board.
My very first attempts used STFM Disco board (ARM-M4) I bought for 16£ and overclocked to 220 Mhz. The problem was it advertised USB 2.0, but only so called Full Speed (12MBit) not the High Speed (480MBit) which I didn't realised at that time. I even made USB driver for sending screens to it. It was working wery slow (1 FPS) but at least I learned how the video signal is constructed how to make 'hardware' scanlines  etc. Even today a FPGA board with all the required stuff is about 2x as pricey as Beaglebone Green. I'm not saying BBG is better than FPGA (on the contrary, there is a slight GPIO jitter that more sensitive LCD TV's don't accept), but for me (CRT TV) it works well enough.
« Last Edit: October 08, 2016, 03:17:35 pm by olin »
olin
« Reply #15 on: October 08, 2016, 06:30:32 pm »
The cheapest  FPGA with RAM, USB 2.0 (High Speed) I could find is this one ($59):
https://www.aliexpress.com/item/Free-Shipping-CY7C68013A-USB2-0-High-speed-fpga-development-board-altera-data-acquisition-board-EP2C5Q208/1885804485.html
But bear in mind this is undocumented board with maybe some bits of doc written in Chinese. The FPGA chip on this board is quite old one and is probably not supported any more by using current Altera SDK, so it might be a challenge to make it work.
If anybody can find anything cheaper than that let me know.
Another more expensive board (with all the required stuff) is for example this one:
http://www.aessent.com/products/aes220-minimodule.html#!/~/product/id=52901862
It seems to have good documentation and even USB SDK with samples, but the cost is around $100.
MCU based cheap board that 'might' be suitable as well is the latest Nucleo board NUCLEO-F767ZI using Cortex M7 chip. There is both Ethernet and USB and the board is very affordable (around $23).
olin
« Reply #16 on: February 10, 2017, 08:10:31 pm »
I did some screen lag testing of Arvid output. At first the results didn't look good. There was ~42 milliseconds lag behind SDL screen output when I used my 'development' LCD TV and Arvid was connected to my laptop via ethernet switch. Then I did the same test with my CRT TV and the result were quite different, this time the SDL screen was lagging behind Arvid by ~25 milliseconds (Yes, Arvid displayed image quicker than SDL screen on my Linux laptop). I was wondering why is the lag difference so big (4 frames at 60Hz) then realised I didn't use ethernet switch with my CRT TV test. Then tested again LCD TV with direct network connection and the result shows the ethernet switch adds roughly extra 16.6 milliseconds to the screen lag.
For the tests I used modified arvidmame with SDL output where I copied the emulated frame onto the SDL screen (normally it displays just the arvidmame splash screen). Then I used my camera to take shots. Note I've also added 2-line frame counter to the screen image to help me identify the screen lag. The frame counter consists of 2 lines , the top one showing frame_number / 10, and bottom one showing frame_number % 10. The bottom line digit is displayed shifted by 8 pixels for every digit to prevent smudging of the digit (if displayed on the same spot). So if line 2 of the frame counter reads 87, that means the shot was taken in between frame 8 and 7.    Results are in the picture  bellow.
« Reply #17 on: February 11, 2017, 07:10:38 am »
Hi olin,
Thanks for posting about your tests. I'm assuming when you mention SDL it's because you're doing your tests on Linux. Does Arvid MAME support Windows 7+? If so, it'd be very interesting to do your measurements there too. The Linux/SDL combo is known to be plagued with latency already (hopefully this will be solved in the future). Ideally, your testing setup should include a LED wired to a switch button for input, so you can measure absolute latency of the whole chain.
olin
« Reply #18 on: February 11, 2017, 07:35:37 pm »
Hi Calamity,
yes there's several builds of arvidmame available for different OS'es. I made measurements on my spare laptop (Core i3) running Win7 and also on my mini PC (NUC-like, Celeron J1900) running Win8.1, both are 64 bit versions - see the image bellow. Win7 didn't show much of difference compared to Linux as SDL was lagging behind Arvid regularly ~1.3 frame. Win8.1 on the other hand improved considerably lagging behind Arvid most of the time around 0.7 frame with occasional drops to ~1 frame. Both Win computers used the same PC monitor. Just for the record I run the tests with the same binary and the same SDL dll on both computers, also Arvid was connected directly (no ethernet switch) in both cases.
As for the latency of the whole chain, you are absolutely right, that's very important as well. I didn't modify the way mame checks for input in arvidmame, so I expect the input lag will be similar to stock mame.
The goal of this exercise was to find out whether 100 mbit ethernet is causing Arvid a significant screen lag or not. My conclusion so far is: yes there is a lag, but on par with SDL output, usually slightly better than that.
maiki
  • Last login:April 22, 2019, 05:51:29 pm
« Reply #19 on: February 19, 2017, 11:41:39 am »
As for USB, I have a USB 2.0 analogue TV capture device and it is capable of capturing the standard NTSC / PAL, even from not such standard Atari 2600 games, and yes, at full framerate (240p if you wish). So USB should really not be any limitation regarding standard video traffic.
As for the 15 kHz device, yes, that is definitely needed. How about Uzebox and its implementation of the AD723 / AD725?
no more messing with irrelevant PC VGA cards
olin
« Reply #20 on: February 19, 2017, 05:54:59 pm »
I didn't know about Uzebox, it looks like a cool project. But 4 kbytes or RAM is insanely small IMO. Anyway it doesn't have USB(2) port so you can't transfer images (generated by mame) to it in real time (at 60Hz). If I understand correctly Uzebox does output 15kHz video signal via 3-3-2 RGB DAC (which should be compatible with some newer arcade monitors). The AD725 is a video signal converter producing S-video or composite video out based upon the RGBS input. It's purpose is to be able to hook Uzbox to standard TV (without RGB inputs). So AD725 itself doesn't generate the signal, just transforms it (video quality is degraded in the process). Atmel MCU chip does generate the video signal via GPIOs and the DAC made of resistors - similar way how Arvid does it. Unfortunately low cost Atmel chips don't have high speed interface so you can't pump them with video stream. Anyway, it's an interesting tip.
I also had a look at a cheap USB2 cypress board:
http://www.ebay.co.uk/itm/EZ-USB-FX2LP-Cypress-CY7C68013A-USB2-0-Developement-Board-/232072867953?hash=item36089ef071:g:CIYAAOxy-WxTD-te
People use it as a high speed aquisition board for receiving digital signals and sending them to the host PC. Something like a logical analyser. The good thing is: it has documentation, it is programmable (linux code exists) and there's plenty of GPIO's to generate 15 bit RGB signal. It is possible to reverse the direction of data flow - so rather that reading GPIo's you can output signal and generate RGBS.  It seems to run on 48MHz which is not bad (Arvid's PRUs runs on 200Mhz though), but that might be slightly limiting (in terms of which video modes would be possible). Still an option worth investigating. I have one sitting on my desk, but didn't find time to do something useful with it yet.
donluca
  • Last login:March 08, 2026, 04:59:21 am
« Reply #21 on: February 20, 2017, 04:14:39 am »
This is really, really interesting, as this enables us to generate EVERY SINGLE VIDEO MODE ever existed without limitations (other than bandwidth due to high resolution, but I think we're talking mostly 15khz here).
While the super modes in GM with the ultrawide horizontal resolution is ok most of the time as it gives us enough granularity, I'd still go for a 1:1 with the original resolution where possible to achieve perfect accuracy.
And, if I understood correctly, it only gives us a handful of ms of lag more than a ATI videocard, which is absolutely tolerable.
Please keep us updated on the matter.
2.- Inflatable dolls
« Reply #22 on: February 20, 2017, 04:45:59 am »
Well... that's assuming a lot. However, latency could theoretically be reduced to zero (or close enough).
And yes, I definitely see this route (Arvid) as the future of analog video for emulation.
donluca
« Reply #23 on: February 22, 2017, 07:13:04 am »
Yeah, sorry, should have phrased that differently as that's my own opinion, referred to *my* tolerance :P
olin
« Reply #24 on: March 04, 2017, 06:56:34 pm »
I hope I’m not too boring wit this stuff, but I managed to shave off some more milliseconds from the screen lag on Arvid. The 'trick' is simple: normally the game is emulated and rendered to a frame buffer (not on the screen yet) in fraction of time of a frame  - let's say 4 milliseconds. The rest of the time (12.6 milliseconds) the renderer waits for vsync event from the video card and then the frame buffer is displayed (at leas that's what happens in arvidmame). So I thought why not make the gap between the time the emulation of single frame ends and the time vsync happens smaller? Why wait 12 milliseconds if I can wait only 2? So I programmed something I call 'virtual vsync' - that is a vsync that happens when line 128 is rendered rather than the last line is rendered which is the normal vsync event. As I can trace hsync events in Arvid, it was simple to do. And It looks it works quite well - see the screen shots from my Win 8.1 mini PC. Previously the screen lag was approx. -0.7 frame on my Win 8.1 set-up (ahead of SDL by ~11.6 milliseconds) now the gap is even bigger by (as expected) another 0.5 frame. On the latest screen shot the gap is between approx. -1.2 to -1.5 frames  - that is Arvid is quicker than SDL on my Win 8.1 by ~ 20 milliseconds. Was it noticeable during play ? To my surprise yes it was! With some simple games (raiden) I could even go to line 192 for virtual vsync to make the screen lag even smaller, but more demanding games had artefacts on the screen (tearing effect) as the emulator could not finish all it had to do within such small time gap (at least on my 2GHz ARM Cortex A-15) - so I went back to line 128 where the games are fine.
If you are interested to see more of the screen shots I did, you can find them all zipped in the original format from my camera here:
https://app.box.com/s/mtfjkjwwc12bede5kkn99j0n40v2fevb
« Reply #25 on: March 05, 2017, 01:51:54 pm »
Hi olin,
That's exactly the same feature as "frame delay" in GroovyMAME. It certainly works :)
donluca
« Reply #26 on: March 07, 2017, 04:17:42 pm »
Hi olin,
That's exactly what I was thinking while I was reading olin's post, lol.
Keep those updates up olin, I'm really interested in this project.
Also, can you do a comparison between this latest iteration and d3d9ex video backend on your windows machine?
olin
« Reply #27 on: March 07, 2017, 07:18:05 pm »
Thanks for the info. I'm not familiar with GroovyMAME, is there more techniques in GroovyMAME that reduce latencies (screen and input) compared to stock mame? If you don't mind I'll use the 'frame delay' term in arvidmame as well.
That's a slight problem - those rendering engines are not easy to combine (you can have one or another, but not both at the same time AFAIK). SDL was easy to (ab)use as I create SDL window in arvidmame for reading the input events.  Maybe I could sneak arvid rendering in the d3d3ex code somehow, but I didn't look how easy/hard it would be. Another problem is the compiler environment. Currently the windows code of arvidmame is cross-compiled on my linux machine (it's convenient and virus free) and I'm not sure I have compatible d3d9ex headers and libraries (if at all mame can be build on linux with d3d9ex ). I would have to investigate.
donluca
« Reply #28 on: March 08, 2017, 07:04:39 am »
I see.
I think someone calculated the difference in lag between SDL and d3d9ex somewhere, that could be a good starting point to know how much lag arvid has against a dedicated Windows d3d9ex machine with GroovyMAME.
Anyway, I'm seriously considering going the arvid way so I can use my iMac to play MAME on my cabinet with 1:1 resolution and (hopefully) low lag.
The only thing I need to do is to modify the resistor values on the output so I have 5v on the RGB lines, this way I can feed the output to my Nanao MS8-29 in my Astro City cab.
olin
« Reply #29 on: March 08, 2017, 06:35:46 pm »
Arvid depends on BeagleBoneGreen GPIO voltage to produce video signal levels (GPIO output is 3.3V). So modifying the resistors will give you no more than 3.3V IMO. This might be enough to drive your monitor, on the other hand the colors won't probably look right.
For something more serious you may need a video amplifier made out for example of high-speed op-amp IC (max4386). I was thinking about raising Arvid's video signals to 5V recently and already designed the following little add-on board (see the snapshot). It doesn't look pretty, but allows me to experiment at least on my supergun (I don't have arcade monitor available) with current Arvid board. I've soldered it literally just yesterday and tests on the scope look promising (everything looks as expected, levels amplified between 0-5Volts).
If you decide to build Arvid let me know I can send you unpopulated PCBs (arvid and the amp addon pcb).
Edit: removed el5462 op-amp, as it is current feedback amp, not voltage feedback amp...
« Last Edit: March 08, 2017, 07:09:51 pm by olin »
donluca
« Reply #30 on: March 09, 2017, 02:38:39 pm »
This is something I really want to do sooner or later, but right now I'm kind of broke (just got my cab and spent lots of money on components to get it working right) and my spare time is running really thin.
I was looking at BBB yesterday and it doesn't come too cheap either, it's 60€ + shipment here in Italy.
I'll definitely follow Arvid's development and I'll dive in as soon as I have some cash back and some free time to dedicate to this project.
olin
« Reply #31 on: March 09, 2017, 07:07:45 pm »
Do not use BBB they are overpriced, use BBG instead. They are  cheaper and do the job equally well, actually all my latest development and testing is on BBG, so I definitely recommend BBG. You should be able to get it for 40€ including shipment directly from seeedstudio ($39 + $3 shipment, after currency conversion ~40€). I bought few from them, the shipping cost was about 3$ to the UK. Anyway, there is no rush.
donluca
« Reply #32 on: March 10, 2017, 11:33:22 am »
Thanks for the link! I'll definitely buy it from there.
Meanwhile, I was wondering if Arvid could be implemented into groovymame. It shouldn't change much theoretically, if I'm not wrong it's about adding support for a new hardware.
maiki
« Reply #33 on: April 13, 2017, 10:59:58 am »
I really wish you guys with the knowledge manage to build this device. I am literally sick with all that PC VGA cards nonsence for years and years and no definite standard nothing. One things works, another one does not. Perhaps something like that RGB output module for Raspbrry Pie (Pi2scart)?
olin
« Reply #34 on: April 13, 2017, 07:46:04 pm »
Thanks for the kind words. A very similar device (not based on FPGA but MCU) has been already built. If you scroll few posts above you'll see the board and if you scroll even more you can see some images it produces on the SCART TV (RGB). If you are brave and live in Europe you can buy one at ebay these days :)
antoniomauro
  • Last login:March 10, 2026, 05:57:43 am
« Reply #35 on: April 27, 2017, 11:26:25 am »
Where can i find a board to assemble/test this very promising solution?
olin
« Reply #36 on: April 27, 2017, 07:33:42 pm »
If you want to try super cheap and have a Euro SCART TV you use just a bread board, resistors, BBG, SD card, SCART socket (or SCART cable if you are OK to solder the wires directly to it).  The IC chip only helps with booting - BBG uses some of the GPIO to determine the booting sequence. But if you connect the resistors (wires going to the resistors) AFTER the boot, you should be fine and no IC is required. To make the assembly even more quicker/simpler don't use all 5 bits (resistors) per color, but use only 2 or 3 bits per colour (wire up the smaller values , 510, 1k and 2k2). Even though you will get less colours you can still observe the latencies and all other stuff you are interested in (old games from early 80's didn't probably use more colours anyway). The schematic is on the ARVID's main page: http://mujweb.cz/molej/arvid/index.htm
If you'd prefer a photograph how it should be wired on the breadboard I can probably do it in few days for you.
If you don't have Euro SCART TV (that accepts RGB signals) but only 15kHz Arcade monitor, things might be more complicated, depending on your monitor (whether it accepts 1V signals, or signals up to 3.3V). If your 15kHz Arcade monitor only accepts 5V signals you'll probably need a video signal amplifier.
For anything more permanent you can buy a PCB (gerber files are on the same site) from an online PCB service and then solder parts on it (resistors and an IC, pins that connect to BBG). If obtaining a PCB seems too complicated then just PM me and I can send you one unpopulated PCB (I still have few left).
funkycochise
  • Last login:October 22, 2019, 07:35:18 am
  • 8 bits generation
« Reply #37 on: April 29, 2017, 01:51:06 am »
Very interesting topic. Very original approach.
anyone has a link for the Bgg or Bbb chip ?
Seems very promising. I am very motivated to build one and see what I can give to the project,
in a matter of GUI on cab.
maiki
« Reply #38 on: April 29, 2017, 08:47:45 am »
So, is Arvid the right thing for me?
Can I create custom horizontal resolutions with it or does it restrict me to those listed in the specifications?
Does it work in Windows with any software (version of MAME) or is it required to reprogram/patch the programs for it?
donluca
« Reply #39 on: April 29, 2017, 12:14:55 pm »
I think I can reply to some of those questions:
You need a customized version of the software you want running.
There is a MAME version called ArvidMAME iirc which is tailored to use this project, so you have to use it.
It will not work out of the box with any software.
Also, talking about arcade monitors, does Arvid output a DC coupled or AC coupled video signal? Does it output standard 0.7V?
I'm asking because I'm working on an adapter to make consoles work on my cabinet and I'm having a hard time finding something "universal" which works with all consoles and delivers a good picture. A video amp alone is not enough, as console outputs are AC coupled and arcade monitors expect DC coupled video signals, so at least a clamp is needed.
