Author Topic: Trackball installation 1 wire at a time.  (Read 1456 times)
TNHANK
  • Last login:September 15, 2016, 11:28:26 pm
« on: September 10, 2016, 01:09:16 am »
I keep reading about some boards being track ball
Compatable and some are not.  Can you just wire a trackball
The same way you wire any joystick?  If I have a jamma cab.
Can't I splice the wires going to the player 1 joystick and connect to the trackball?
  • Online Online
  • Last login:Today at 11:48:01 pm
Re: Trackball installation 1 wire at a time.
« Reply #1 on: September 10, 2016, 02:37:57 am »
Unfortunately, it won't work that way.
The joysticks are microswitch devices that require a digital encoder -- either keyboard-style (IPac, etc.) or gamepad-style. (GPWiz, etc.)
A trackball requires an optical (mouse) encoder to translate changes in the quadrature waveforms into mouse movements.
Check with the vendor where you got your XXXX-in-1 (that's what you want to connect the trackball to, right?) and see if they have a trackball/interface that is compatible with the drivers already on your XXXX-in-1 -- it's probably going to be a PS/2 version that plugs into the mouse port of the computer board.
Once you find and install a suitable trackball/interface, there are videos on Youtube showing how to change and save the MAME control settings for trackball games.
