Author Topic: crtemu driver and groovymame help ?  (Read 1869 times)
geordiemick
  • Last login:October 03, 2016, 07:12:19 am
« on: September 09, 2016, 02:10:02 pm »
I have just installed groovymame and crtemudriver in my cab this week, But im having some screen size issues , Im running on a 20inch crt tv through rgb scart.on a radeon 5450.
screen res set at 640x480@50hz through arcade osd.
The problem im having is with my screen position, if i adjust my desktop position through the Tvs pots and get it perfect, when i go into groovymame, the screen position is way out of position or too high up the screen . i can adjust the pots with groovymame running and get it perfect, but when i go back to the desktop ive lost screen position, taskbar etc,
Switchres appears to be working correctly as its switching resolutions per game.
Any ideas thanks
keropi
  • Last login:December 28, 2022, 11:06:35 am
Re: crtemu driver and groovymame help ?
« Reply #1 on: September 10, 2016, 06:06:28 am »
Can't you use 640x480@60hz and adjust orientation there? Why did you use 50hz? Even if your tv is PAL since you are using RGB SCART 60hz is no problem.
I had the same test setup for a little while, running both a tv and a 1084 monitor - I didn't have to adjust much : not every game was perfect but they were all centered and needed minor corrections that you can live without  :)
  • Last login:January 23, 2026, 06:10:10 am
« Reply #2 on: September 11, 2016, 02:36:12 pm »
Check this.
