Author Topic: Ipac Ultimate LED power  (Read 3131 times)
Taflad
  • Last login:September 06, 2016, 01:43:40 pm
« on: September 06, 2016, 03:45:18 am »
Hi All,
I have an IPAC ultimate, and have just bought 18 ultralux buttons with LEDs. The PC I have has no MOLEX style power connectors, and I see the LEDs are 5V. I plan to run the power for the LEDs through the IPAC using a USB to DC cable I have made. Will this cause any issues with the board? Will the USB 500mA be enough (apologies, my electronics knowledge is almost non existent!)
I used to have 12v LEDs connected using the provided molex to DC cable, but that PC is no longer used.
Many thanks
Titchgamer
Re: Ipac Ultimate LED power
« Reply #1 on: September 06, 2016, 03:58:10 am »
Either but a Molex splitter or just cut into one of the lines and joint it.
Problem solved :)
Taflad
« Reply #2 on: September 06, 2016, 04:19:14 am »
Problem solved :)
Thanks very much for the reply. The issue I have is that the PC im using is SFF. it has 2 x sata power connections (both used to power HDDs). I have no other power connections on the PSU, hence I hope the 5V usb will be ok. From your reply, I assume it will be?
Titchgamer
« Reply #3 on: September 06, 2016, 04:22:52 am »
In that case get a sata splitter and a sata to molex adapter.
I would think you could power them from a USB though yes, I think USB can carry something like 2-3A which should be plenty for your LED's but I have never tried it. Ive always come straight off the PC's PSU.
Taflad
« Reply #4 on: September 06, 2016, 04:48:26 am »
Ahh ok.
Well Ill ask one last question. I have found a 12v 0.5a DC adapter with a positive polarity. Can I use that into the IPAC ultimate to power 5v leds?
Titchgamer
« Reply #5 on: September 06, 2016, 04:57:48 am »
No would need to be 5V otherwise they would be over bright or blow!
Titchgamer
« Reply #6 on: September 06, 2016, 05:08:29 am »
Just remembered you are going through a Pac so yes you should be able to use 12v if needed just double check the paperwork.
But i still think its easier breaking into your computers PSU :p
« Last Edit: September 06, 2016, 05:11:23 am by Titchgamer »
Taflad
« Reply #7 on: September 06, 2016, 05:13:08 am »
Brilliant, thas very much for such fast responses and information. I think I will just splice into the 12V on the sata to be honest :D thanks alot again
Titchgamer
« Reply #8 on: September 06, 2016, 05:55:27 am »
No prob but these are your best solution:
https://www.ebay.co.uk/itm/351174713105
https://www.ebay.co.uk/itm/310856850299
You can split off your existing sata with the sata splitter one to hdd and one to the 2x molex adapter which gives you 1 extra for expansion in future.
« Last Edit: September 06, 2016, 06:04:06 am by Titchgamer »
