Author Topic: Ball Buster - A Gingerballs Tribute  (Read 36961 times)
thomas_surles
Re: Ball Buster - A Gingerballs Tribute
« Reply #80 on: October 24, 2016, 06:11:35 pm »
A bit off topic here, but how did you like working with the blondewood? I am going between that and MDF for my cabinet, and both have their pros and cons. This new cabinet will most likely be stored in my unheated garage, and while dry, does get damp here in New England. MDF is making me nervous about moisture, but the plywood isn't true 3/4" so that messes up t-molding.
On a pinball note, this thing is peachy! I wish you had utilized a plunger, but I am sure a fire button is much easier to mess with...lol. Nice work!
Mdf was my first choice, but I went to the wrong lowes and wasn't about to drive across town to the other, so I went with what they had. You have to be careful working with the blondewood as it chips easily when cutting. It feels sturdier than mdf and it might hold up longer. Just slightly more difficult to work with, but not bad. Also mdf was a little more than $10 cheaper.
As for the fire button, it was just so much cheaper and easier. I had every intention going in to use some sort of plunger. I even started a thread in the pinball section and was going to go with PL1's mouse option, but I passed out.
thomas_surles
« Reply #81 on: November 11, 2016, 12:06:27 pm »
I got around to cutting a sheet of steel to cover the palm rest/lockdown area. The plexiglass for the playfield is there, but the monitor and plexi need to be cleaned. Still need a piece for the backglass monitor.
Still working on sanding the metal pieces and polishing them. Also they are not screwed on yet.
Here is a little demo video
efp9teen78
  • Last login:January 24, 2026, 12:23:52 pm
« Reply #82 on: November 11, 2016, 12:38:36 pm »
Man that is looking better and better. And also love the Journey in the background
thomas_surles
Re: Ball Buster - A Gingerballs Tribute (Finished)
« Reply #83 on: December 27, 2016, 01:05:42 pm »
Finished. The metal still needs to be properly polished, but I'm calling it done. Force feedback may come in the future.
« Reply #84 on: December 27, 2016, 01:20:07 pm »
looks good!  :applaud:
thomas_surles
« Reply #85 on: April 30, 2017, 10:26:37 am »
I decided to upgrade the Ball man. Got some new parts in and im working on the wiring for the new upgrades.
But for now here are some coin door pics with the volume knob finally on.
As you can tell from the hot glue, i was only worried about functionality and outside appearance.
The inside could be a roasted dog turd for all i care, as long as it works.
thomas_surles
« Reply #86 on: April 30, 2017, 05:16:24 pm »
Force feedback coming soon
NIVO
« Reply #87 on: April 30, 2017, 07:39:23 pm »
this thing needs ladies mannequin legs.....or leg lamp major award legs
Slippyblade
« Reply #88 on: May 09, 2017, 08:16:05 pm »
Can you linky to that solenoid board?  Please and thank you?
thomas_surles
« Reply #89 on: May 09, 2017, 08:38:39 pm »
Sure, here you go
 http://www.ebay.com/itm/112144067285
Slippyblade
« Reply #90 on: May 09, 2017, 09:01:19 pm »
Thank you.  Finding things like that is kinda hard when you're not even certain what they're called!
thomas_surles
« Reply #91 on: May 09, 2017, 09:35:47 pm »
Well lets hope it works like the sansmart relay.
rablack97
« Reply #92 on: May 09, 2017, 09:46:16 pm »
those chinese solenoids suck, i had 10 i would of sold to you and i have a whole set of seimens contactors i'm trying to get rid of.  Make sure the nuts on the ends are tight over time they loosen and the whole thing comes apart.
and dont forget your diodes.
and why didn't you just get the 16channel one? for 18.00.  That way you can expand to more toys if you want to and you know it works http://www.ebay.com/itm/like/291989573347
heres one for 12.00 http://www.ebay.com/itm/New-16-Channel-5V12V-Relay-Module-Board-For-Arduino-PIC-AVR-MCU-DSP-ARM-PLC-VIC/132168997124?_trksid=p2141725.c100338.m3726&_trkparms=aid%3D222007%26algo%3DSIC.MBE%26ao%3D1%26asc%3D20150313114020%26meid%3Dc7e81f47db6145f0a331534040cfd8d4%26pid%3D100338%26rk%3D4%26rkt%3D29%26mehot%3Dlo%26sd%3D291989573347
« Last Edit: May 09, 2017, 09:52:16 pm by rablack97 »
thomas_surles
« Reply #93 on: May 09, 2017, 09:59:14 pm »
I wnt with the 8 instead of 16 because the cab is so small that i didnt want to go overboard with too much stuff. Thanks for the heads up on tightening the solenoid nuts. Wish i would have known anout the contractors you have earlier.
thomas_surles
« Reply #94 on: May 10, 2017, 09:58:26 am »
Well i was planning to wire up the solenoids today but i cant find my diodes, so i orderd some new ones. I swear every time my wife cleans she throws away everything that she dont know what it is.
NIVO
« Reply #95 on: May 10, 2017, 11:58:14 am »
lol. guys have a system. It may look like a pile to wimmins, but we know right where stuff is..............except where we are headed or where we put our keys.
thomas_surles
« Reply #96 on: May 10, 2017, 12:43:56 pm »
Story of my life right there. I can remember where i left a tiny micro sd card last year but can never find my keys when its time for work
rablack97
« Reply #97 on: May 10, 2017, 03:29:39 pm »
Get you some cms002's
and plastic or metal L Brackets
the cms002's make a good sound for bumpers and sling shots, the L brackets are for the flippers.
not sure if you've done your research but vp tables work out the box for force feedback, pbfx2 and future pinball use doflinx for feedback.  ultradmd tables feedback have to be added into the dofconfigtool as they are not rom based.
thomas_surles
« Reply #98 on: May 29, 2017, 09:34:44 am »
I got everything wired up but can't for the life of me figure out how to get the solenoids setup with dof. Any help would be great.
rablack97
« Reply #99 on: May 29, 2017, 01:16:14 pm »
i used led wiz, malenko would know what needs to be done with the USB board and and no ledwiz
« Last Edit: May 29, 2017, 01:21:41 pm by rablack97 »
thomas_surles
« Reply #100 on: May 29, 2017, 02:01:40 pm »
Isnt it the same concept as the led wiz?
rablack97
« Reply #101 on: May 29, 2017, 06:49:58 pm »
have you setup your dof config tool account yet?
thomas_surles
« Reply #102 on: May 29, 2017, 07:02:16 pm »
Not really. I looked at it a bit. Is internet required on the cab pc to set it up or can i export the info ro a flash drive? No internet where the cab is currently stored. I can plug my phone into it and use my 4g
rablack97
« Reply #103 on: May 29, 2017, 07:59:18 pm »
once its setup then you it creates necessary files for you to put in your dof config folder. so you can download, put on thumb drive and add to your cab.
thomas_surles
« Reply #104 on: May 29, 2017, 08:43:38 pm »
Ok cool i barely checked that out today and it came off as this online only thing. I will give it a go.
