Author Topic: Using a PCI Express VGA on a mobo with only PCI slot via adapter, yay or nay?  (Read 1947 times)
fcobenitez
  • Last login:May 23, 2022, 12:36:40 pm
Is this possible?
I've found some really cheap Intel Atom kits that should run everything I need, but the problem is that they only have one PCI slot avaliable, not even PCI Express x1.
I play mostly MAME, and I think that I've read that MAME uses mostly only CPU power, right?
Could this work?
Thanks guys!
UEDan
  • Last login:November 10, 2019, 05:54:08 am
Yeah MAME is pretty much all CPU.
Either way, you won't be able to add a PCIe card on an PCI slot....
fcobenitez
I don't know why I even thought that such an adapter existed...
Thanks UEDan  ??? ???
