Author Topic: GroovyMAME 0.227 - Switchres v0.017t  (Read 770249 times)
0 Members and 15 Guests are viewing this topic.
pakoman
  • Last login:November 05, 2024, 08:36:26 am
Re: GroovyMAME 0.216 - Switchres v0.017p
« Reply #1040 on: December 03, 2019, 08:21:47 am »
So mame is not accurate with interlaced systems?
Never had the chance to compare on the same arcade cabinet the real jamma interlaced game vs emulation and I've always been curious about the result because I don't remember Rampage or Popeye to look so bad in the arcades. Maybe it was a smaller screen as well...
In the other hand, I compared several progressive scan games (jamma vs emulation) and apart for the need to adjust the brightness and maybe the screen size/position it was exactly the same.
pulse
  • Last login:April 15, 2024, 01:26:18 pm
« Reply #1041 on: December 03, 2019, 11:25:44 am »
are you saying that for a game with 60 fields per second, MAME outputs 30 progressive frames in a second? what exactly does mame do to composite the image that results in data loss?
u-man
  • Last login:May 20, 2024, 03:53:16 pm
« Reply #1042 on: December 03, 2019, 01:11:41 pm »
It is non-existent. MAME can not do interlace. We all can thank Calamity that we have a option for interlace in GroovyMAME, but like i said, that option comes AFTER the output from MAME itself.
You partially answered your own question. I dont know how much frames MAME outputs to compensate interlace, it could be 60 progressive frames or it could be 30 progressive frames. The main point is, that if the original game has interlaced output, then the fields are blended for progressive output.
EDIT: That is how MAME handles interlace and this process is destructive, till today there is no solution or blending method, that can make this process non-destructive/revertable. Once a blending/conversion is applied, there is no undo or reverting process. What is more worse is, you lose the resolution and half of the frames. This is the reason why no blending/conversion looks as good as the original interlaced frames, provided you watch this on a CRT.
One of the biggest problems for the MAME devs is, that no one use a CRT as a display, ergo they have nothing to proof with. Interlaced material can only be properly displayed on a CRT, which makes it impossible to show MAME devs a evidence, what kind of data is really lost. This may explain, why they did not care about interlace that much. What MAME needs, is a switch where a user can define what kind of output is wanted (something similar to GroovyMAME´s monitor switch). Currently all interlaced stuff in MAME, is postprocessed with blending.
So i am not a game-expert nor do i know all interlaced games, but if a game has interlaced output and it is in use other than some resolution switching for in game menues etc., then there will be data/motion lost, if outputted through MAME (even if MAME has 60 blended, progressive frames). One example i posted years ago, is Atari 2600. Play H.E.R.O and press pause in a scene with lot of motion and you will see a blended progressive frame, that originally is not there.
If someone here knows good examples for interlaced games, please tell us more :) . Games that really use the advantage of interlacing. A bad example would be a game that internally creates progressive frames and the output is interlaced, which is possible but without any benefits you usually would have. One great example is the Laserdisc game Firefox. It uses even interlaced real life footage as a background for the game.
There is more to write on that topic, but basically it is this. If there is interest, i can write more for it.
« Last Edit: December 04, 2019, 04:47:49 am by u-man »
"Computer games don't affect kids; I mean if Pac-Man affected us as kids, we'd all be running around in darkened rooms, munching magic pills and listening to repetitive electronic music."
Recapnation
    • Eiusdemmodi
« Reply #1043 on: December 04, 2019, 07:03:15 am »
Guys, took the liberty of starting a new thread; this is getting too off-topic:
http://forum.arcadecontrols.com/index.php/topic,161548.0.html
oomek
  • Last login:October 24, 2025, 01:13:40 pm
  • Mame forever.
    • https://github.com/oomek
« Reply #1044 on: December 09, 2019, 03:27:09 pm »
Did anyone compile GM 0.216 x64 d3d9ex with nonag patch yet? b4nd1t0 seems lagging this time.
b4nd1t0
  • Last login:January 29, 2026, 03:45:54 am
    • b4nd1t0's repository
« Reply #1045 on: December 10, 2019, 09:29:28 am »
Hy @oomek, i have the cab monitor broken and i thought no one used the version compiled by me, anyway, if you need, it's ready in the usual place here  :cheers:
Substring
  • Last login:Today at 03:00:23 am
  • Forking GroovyArcade
    • GroovyArcade active fork
« Reply #1046 on: December 10, 2019, 09:46:21 am »
probably today's most stupid question, but what's the difference between the no nag patch, and setting skip_gameinfo ?
tom5151
  • Last login:September 16, 2023, 09:21:11 am
« Reply #1047 on: December 10, 2019, 10:35:54 am »
Thanks, I use your build and wait for them each month :)
Envoyé de mon GM1910 en utilisant Tapatalk
oomek
  • Mame forever.
« Reply #1048 on: December 10, 2019, 11:32:31 am »
Thanks, I always use your build.
Torkyo
  • Last login:November 29, 2023, 07:12:04 pm
« Reply #1049 on: December 10, 2019, 05:02:39 pm »
#me too
thanks b4nd1t0
grande!
Paradroid
    • SCART Hunter
« Reply #1050 on: December 10, 2019, 07:53:28 pm »
Yep, another nod. Think I'm up to around 8 cabinets running your build! Cheers b4nd1t0! :)
Substring
« Reply #1051 on: December 25, 2019, 06:29:01 pm »
Ho ho hooooooooo Merry Christmas and Happy New MAME 0.217  :)
keropi
  • Last login:December 28, 2022, 11:06:35 am
« Reply #1052 on: December 26, 2019, 11:20:02 am »
merry xmas!
I am about to update from 0.192 to 0.217 once the GM patch becomes available, is there anything new I missed? maybe some groovy new option ? (using win7x64)
thanks!!!!  ;D
pmc3
  • Last login:October 21, 2025, 04:15:51 pm
  • 404
Re: GroovyMAME 0.217 - Switchres v0.017p
« Reply #1053 on: December 26, 2019, 01:12:43 pm »
hi,
several errors when patching mame with 217.17p (lot of "ignore" message). This has never happened before. does it matter or not?
  • Last login:Today at 04:18:09 am
« Reply #1054 on: December 26, 2019, 01:13:45 pm »
GroovyMAME 0.217 is out!
Release notes:
Finally, GroovyMAME has its own repository in GitHub. Thanks specially to Substring and Keilmillerjr for helping me in the process.
People wanting to roll their own builds will now have more options:
1.- Simply download the source package from the releases page and compile it*
2.- Clone GroovyMAME's repository locally, and make sure to checkout the correct branch. There will be a branch for each GroovyMAME's release, named e.g. groovymame0217.
3.- Download GroovyMAME's patch and apply it manually over MAMEdev's source package, this way:
c:\mame_source>patch -p1 <0217_groovymame_017p.diff
c:\mame_source>make
*Keep in mind GitHub's source already contains D3D9ex applied. If you're building for Windows XP, you must not apply the D3D9ex patch, so method 3 is your best option.
« Last Edit: December 26, 2019, 01:19:54 pm by Calamity »
« Reply #1055 on: December 26, 2019, 01:15:00 pm »
hi,
You were faster than I. Check the new compiling notes, specifically the "-p1" param, instead of "-p0". The new diffs are created from git itself and this change is required.
pmc3
  • 404
« Reply #1056 on: December 26, 2019, 05:56:25 pm »
Thanks Calamity :)
RobeeJ
  • Last login:August 20, 2025, 03:36:59 am
« Reply #1057 on: December 28, 2019, 01:25:39 pm »
This is great news! Thank you Calamity! Hope this will make your life easier too.
telengard
  • Last login:October 21, 2025, 02:12:46 pm
  • Yeah, it's a classic! 21+ on BYOAC and still goin
    • S T U R C A D E
« Reply #1058 on: January 02, 2020, 05:35:29 pm »
Has anyone built a 32 bit version of .217 GroovyMame (can it still be done, I assume so since I have straight up mame 32 bit .217)?  If not, I can do it, but I thought I'd check first.   :)
Updating my cabinet which still runs XP (for many reasons, and it is air-gapped) and hasn't been updated in a couple years.  Thanks for the continued development on this, it's really appreciated!
« Last Edit: January 02, 2020, 05:37:21 pm by telengard »
S T U R C A D E     M.A.M.E. Cabinet
http://www.briansturk.com/mame.html
Torkyo
« Reply #1059 on: January 09, 2020, 06:33:18 am »
Hello there,
checking the download page of CRT emu driver, it seems that the page if offline. I tried the links posted in the main post of this thread.
Is there any information about this?
thanks
Recapnation
    • Eiusdemmodi
« Reply #1060 on: January 09, 2020, 08:52:40 am »
Server issues which hopefully will get solved soon but are out of our reach. Check this:
http://forum.arcadecontrols.com/index.php/topic,141855.msg1704359.html#msg1704359
Internet Archive may also help in the meantime:  https://web.archive.org/web/20190805022158/http://geedorah.com/eiusdemmodi/forum/index.php
Re: GroovyMAME 0.218 - Switchres v0.017p
« Reply #1061 on: February 05, 2020, 06:56:32 am »
GroovyMAME 0.218 is out!
Substring
« Reply #1062 on: February 05, 2020, 07:22:03 am »
w00t :cheers:
R-Typer
  • Last login:September 09, 2024, 12:50:41 pm
  • C64 Rulez!!!!
« Reply #1063 on: February 05, 2020, 01:22:10 pm »
yaaay!!!!  :D
b4nd1t0
« Reply #1064 on: February 06, 2020, 06:33:07 am »
Thanks!!  :cheers:
Doozer
  • Z80 ERROR
« Reply #1065 on: February 29, 2020, 02:52:31 am »
Linux 0.219 binary is on the drive.
« Last Edit: March 02, 2020, 07:28:38 am by Doozer »
MomoneDk
  • Last login:March 07, 2025, 03:01:03 pm
« Reply #1066 on: March 02, 2020, 03:36:50 am »
No patch for windows.....
Re: GroovyMAME 0.219 - Switchres v0.017p
« Reply #1067 on: March 03, 2020, 04:44:18 pm »
GroovyMAME 0.219 is out!
JohnnySeeJohnnyDo
  • Last login:April 01, 2020, 12:40:46 pm
« Reply #1068 on: March 30, 2020, 12:29:38 pm »
How do I disable bilinear filtering in groovymame? It saves in video settings, but for each game it is enabled by default. I turn it off and it works fine until I restart groovymame where it is enabled. Anyway to have it off permanently for each game even upon restarting?
Re: GroovyMAME 0.220 - Switchres v0.017p
« Reply #1069 on: April 06, 2020, 07:55:24 am »
GroovyMAME 0.220 is out!
Re: GroovyMAME 0.221 - Switchres v0.017p
« Reply #1070 on: May 22, 2020, 05:17:37 pm »
GroovyMAME 0.221 is out!
cools
  • Last login:August 19, 2025, 04:19:37 pm
  • Arcade Otaku Sysadmin
    • Arcade Otaku
« Reply #1071 on: May 23, 2020, 02:26:30 pm »
Thank you!
Re: GroovyMAME 0.222 - Switchres v0.017q
« Reply #1072 on: June 27, 2020, 05:03:25 am »
GroovyMAME 0.222 is out!
What's new in Switchres v0.017q (June 2020)
- Improved black frame insertion, as per Blur Busters request. Option -black_frame_insertion (-bfi) now takes an integer that means the number of black frames to insert after the visible frame:
  - For 120 Hz, use -bfi 1
  - For 180 Hz, use -bfi 2
  - etc.
psakhis
« Reply #1073 on: June 27, 2020, 07:49:00 am »
Thank you! This version 0.222 improves performance around 5%!!
u-man
« Reply #1074 on: June 27, 2020, 07:49:31 am »
Oh, that is really nice news.
Calamity you should talk to MAME devs again. It seems that all graphic modes (d3d, bgfx, etc.) will get a major overhaul. Previously a game is rendered and then post processed, depending on what mode was used. In the future, they will render directly with graphic card. What that means for GroovyMame should better be discussed with you and the devs. For example Direct X 9.0 support will definetely be trashed. You should really talk to them, as long as everything is in a early stage.
Be well, good luck, u-man
schmerzkaufen
« Reply #1075 on: June 28, 2020, 08:50:38 am »
Well, if that happens before Groovy gets a vsync_offset slider - the ONE thing it needs to become a full-fledged mainstream build that anyone even inexperienced beginners can enjoy - then f* it and nuke this planet.  :timebomb:
Anuskuss
  • Last login:July 10, 2020, 04:13:59 pm
« Reply #1076 on: July 01, 2020, 02:06:34 am »
Quick question: When artwork is displayed the games don't use the full screen anymore (I did notice artwork_crop 1 but the artwork is so beautiful tho). To me this looks like some kind of integer scaling or something. Can this be fixed or is it a limitation of GroovyMAME?
Edit: Also if you're not aware: GroovyMAME crashes when loading up a screenless system. Both of these issues are probably related to SwitchRes even though I've turned it off (doesn't work on my TV anyway although vanilla MAME does).
« Last Edit: July 01, 2020, 02:39:48 am by Anuskuss »
cools
    • Arcade Otaku
« Reply #1077 on: July 01, 2020, 05:59:47 am »
Probably don't qualify as a beginner... I've never bothered with vsync_offset as it's such a pain to set.
CPU overclock slider needs changing to actual CPU clock too!
« Reply #1078 on: July 01, 2020, 06:33:33 am »
The problem with a vsync_offset slider has already been explained: MAME's UI rendering is so slow that it actually affects the offset required when the slider is shown. Anyway this will be added at some point.
FYI, we're rewriting the whole Switchres module in GroovyMAME, so this will be the build where you can expect to see new features in the near future.
« Last Edit: July 01, 2020, 06:37:50 am by Calamity »
cools
    • Arcade Otaku
« Reply #1079 on: July 01, 2020, 09:44:36 am »
Hit tab, adjust with arrows, hit tab, adjust with arrows - 1000x better than current adjustment method.
