Author Topic: GroovyMAME 0.227 - Switchres v0.017t  (Read 762500 times)
0 Members and 16 Guests are viewing this topic.
  • Last login:Yesterday at 05:28:27 pm
Re: GroovyMAME 0.181 - Switchres v0.016 alpha 5
« Reply #240 on: December 31, 2016, 11:05:06 am »
Just discovered an issue with GroovyMame 0.180 and 0.181 (d3d9ex builds and normal from your site) that does not seem to appear for me in mainline mame 0.181 - my trackball responds either erratically or not at all in trackball games such as Centipede (centiped) and AmeriDarts (amerdart). Running the exe for GroovyMame 0.179 or official Mame 0.181 solves the issue for me, keeping the same mame.in
Thanks for reporting this. I'm almost sure it's due to the "always_poll" patch we added recently. It has always happened, as soon as we introduce a change to reduce latency, the damned trackballs get broken. I'll see what can be done.
Doozer
  • Z80 ERROR
« Reply #241 on: January 02, 2017, 08:56:15 am »
Hi,
To fix the line ending issue, you can execute the following command before applying the patch.
unix2dos 3rdparty/bgfx/include/bgfx/bgfx.h 3rdparty/bgfx/src/bgfx.cpp 3rdparty/bgfx/src/bgfx_p.h 3rdparty/bgfx/src/config.h 3rdparty/bgfx/src/renderer_d3d11.cpp
Cheers,
Thanks Calamity as always!
Btw if anyone has trouble compiling this on Linux, this is what I usually do to fix line endings issues:
mkdir mame181
cd mame181
unzip ../mame.zip
dos2unix ../0181_groovymame_016_alpha5.diff
dos2unix $(grep 'diff -Nru' ../0181_groovymame_016_alpha5.diff | cut -d ' ' -f 4)
patch -p0 -E < ../0181_groovymame_016_alpha5.diff
make
Well not character for character, but it should illustrate the point!
jbraconnier
  • Last login:September 26, 2021, 04:56:30 am
« Reply #242 on: January 02, 2017, 04:40:31 pm »
Hello,
someone has compiled a version for retro arch linux 64 with no disclamer messages ?
I've downloaded and tested the last groovymame 0.181 but warning messages are always displayed.
Doozer
  • Z80 ERROR
« Reply #243 on: January 03, 2017, 03:38:36 am »
Hello,
Indeed, you are right the Linux version on the groovymame google drive does not contain the suppression patch. If you want it, you need to compile groovymame in order to benefit from complete nag screens removal.
strontium
  • Last login:December 02, 2021, 05:12:52 pm
« Reply #244 on: January 04, 2017, 02:05:54 am »
Hey Calamity, not sure if you missed my response #218 where I reported some issues with 1.80 just wondering as others have mentioned since if this has been resolved in 1.81 and what the latest status is on this issue. Thanks again for such a great release.
Strontium  :applaud:
Doozer
  • Z80 ERROR
« Reply #245 on: January 04, 2017, 03:47:26 am »
Strontium  :applaud:
I will create a specific version without XINPUT which was initially used for wiimote and deal with mouse issues. I will put it on the drive for test. TEll me if this is solving your issues.
« Reply #246 on: January 04, 2017, 03:54:55 am »
Don't bother doing that, I almost sure it's the "always poll" what broke the spinners.
Doozer
  • Z80 ERROR
« Reply #247 on: January 04, 2017, 06:03:46 am »
No trouble, it is on its way ;-) The file is now on the drive.
« Last Edit: January 04, 2017, 07:33:04 am by Doozer »
strontium
« Reply #248 on: January 04, 2017, 08:02:53 am »
Hey Doozer and Calamity, thanks for both getting back to me on this so fast. Ok... So I have tested the new file that Doozer uploaded earlier and I'm sorry to say Trackball and spinner functionality is still not working. @Calamity it looks like it must be to do with the "always poll" that you mentioned.
I'll keep my eyes on here and will test anything else that will help confirm if this issue is resolved or not.
Thanks again,
Strontium
krick
  • Gotta have blue hair.
« Reply #249 on: January 04, 2017, 09:09:04 am »
It seems like we might need to have a separate build for games with analog controls.  I'm not sure how that would work for games that have BOTH digital and analog controls, though.
Hantarex Polo 15KHz
GroovyMAME 0.197.017h_d3d9ex
Windows 7 Home Premium 64-bit
Intel Core i7-4790K @ 4.8GHz
ASUS Z87M-PLUS Motherboard
haynor666
  • retro maniac
« Reply #250 on: January 04, 2017, 09:37:22 am »
Bad idea, many people have games on list with analog and digital controls. We already have two builds d3dex and standard and this will complicate groovymame.
extrude
  • Last login:January 29, 2017, 07:20:42 pm
« Reply #251 on: January 06, 2017, 05:09:40 am »
The different versions confuse me, what version should be used for lowest input lag?
keropi, what is the difference in the "arcade-only" version?
I'm using the regular 1.80 version without any extra parameters or settings in mame.ini, not sure if i should switch to D3D9ex and enable framedelay 1 and multithreading 1 for lower input lag?
When I try the versions with D3D9ex, the screen doesn't stretch automatically horizontally and the games runs at over 600% speed.
keropi
  • Last login:December 28, 2022, 11:06:35 am
« Reply #252 on: January 06, 2017, 12:33:04 pm »
I will answer only what I know 100% :)
"arcade-only" is a build that does not have consoles and home-computers in it (MESS is missing in other words and it's like the old days when they were different projects)
multithreading is absent on recent mame versions so the option does nothing anymore. MAME team decided it was not a good thing to have.
D3D9ex version works with less frames in the D3D rendering queue so it has less lag than the normal version. I don't know why you have 600% speed , I suggest you post some logs and settings so someone else or Calamity answer that
Re: GroovyMAME 0.181 - Switchres v0.016 alpha 6
« Reply #253 on: January 07, 2017, 06:39:14 am »
What's new in SwitchRes v0.016 alpha 6 (January 2017)
- Attempt at fixing broken spinner/trackball devices while preserving low latency for keyboards and joysticks. Experimental confirmation needed.
Doozer
  • Z80 ERROR
« Reply #254 on: January 07, 2017, 01:42:10 pm »
Hi, Does it need to be tested under Linux as well?
burn_654
  • Last login:April 29, 2025, 04:25:44 pm
« Reply #255 on: January 07, 2017, 05:46:39 pm »
Alpha 6 (64bit, d3d9ex) solved the Trackball issue for me under Windows 7. :applaud:
Doozer
  • Z80 ERROR
« Reply #256 on: January 08, 2017, 06:58:28 am »
Strontium  :applaud:
Hi strontium,
I have made available the alpha6 Linux build on the drive. I would appreciate if you could kindly give it a try and check if your issue is solved.
Cheers
strontium
« Reply #257 on: January 08, 2017, 09:45:05 am »
Hey guys, I can confirm that the fix has worked. Massive shout out and thanks from myself and on behalf of the community for the speedy turnaround. Great effort guys  :applaud:
Thanks,
Strontium
« Reply #258 on: January 08, 2017, 03:03:35 pm »
Glad to know it worked. Thanks as always to Doozer for building the Linux binaries.
oomek
  • Last login:October 24, 2025, 01:13:40 pm
  • Mame forever.
    • https://github.com/oomek
« Reply #259 on: January 10, 2017, 03:27:00 pm »
I've never tried any linux build of mame. Are there any benefits of the linux build in terms of input and audio latency?
Doozer
  • Z80 ERROR
« Reply #260 on: January 10, 2017, 04:12:04 pm »
I will try to answer some of your questions.
audio latency: Linux uses the ALSA architecture for audio output which is almost RT and the audio_latency setting can be set to 1.0 in mame.ini. You have also JACK audio which is RT compliant. But this is not needed to my opinion.
video output: With the proper 15kHz patch, the Linux kernel offers full flexibility in setting any modeline/refresh rate. The kernel handle all ATI driver calls identically for all the card models that support low dot clock. Linux was supporting 6xxx before Windows due to the unicity of the radeon driver.
input lag: Here the situation has never been totally clarified. With devices operating at 1000Hz we can consider that key/joy inputs are processed fast enough to be handled within a unique frame. SDL with open GL is giving the best compromise and mame is build upon this library. Nevertheless, Linux is considered to be alway 2-3 frames behind Windows and is not taking advantage of DirextX related optimisations.
With the recent introduction of the BGFX rendered within mame mainline, mame will be totally agnostic to the way the video is rendered. This allow at the same time some nice shader effects to be introduced within the video processing pipeline (CRT bloom + raster rendering). This could be the next turn in the way switchres will be implemented. I am personally hoping to see the benefits share between both worlds.
oomek
  • Mame forever.
« Reply #261 on: January 10, 2017, 04:44:21 pm »
Thanks for your comprehensive answer. I believe the only backend available on linux is opengl, which doesn't have any mechanisms reducing frame lag like d3d9ex and dx12. This alone efficiently deters me from even trying it. Still waiting patiently for bgfx to be able to launch mame in dx12 as it would allow for that new borderless true immediate independent flip mode that Microsoft devs are saying should replace exclusive fullscreen and allow to present frames on the next vblank.
Doozer
  • Z80 ERROR
« Reply #262 on: January 11, 2017, 07:30:43 am »
SDL supports several backends. MESA (software 3d) is even possible. Open GL standards is not as bad as it sounds, the underlying technology is the same (linked to HW design, pipeline/shader treatments). The layers from the application to the Open GL stack is the critical point, with Linux not as optimized as DirectX can be. You can give groovyArcade live CD a try to make your own opinion.
mdd45
  • Last login:July 22, 2025, 06:03:10 pm
« Reply #263 on: January 11, 2017, 06:25:59 pm »
Just tried some sega system-24 games and all boot interlaced. 2 of them are crack down and bonanza bros. I've tried groovymame 0181 and 0177 with same results. Any idea what is wrong?
Recapnation
    • Eiusdemmodi
« Reply #264 on: January 11, 2017, 07:43:33 pm »
You need a 24-kHz monitor for System 24 games in progressive. Your logs reveal you're on 15 kHz.
peterson65
  • Last login:December 13, 2025, 03:57:23 pm
« Reply #265 on: January 11, 2017, 09:50:49 pm »
For now here are for your enjoyment some 64bit executables with MKChamp's suppression patch (32bit ones coming later tomorrow)
GroovyMAME64 D3D9ex version: http://www.mediafire.com/?q5gtnk1wiiz7ncx
GroovyMAME64 D3D9ex arcade-only version: http://www.mediafire.com/?6ofsxsyx68n022w
GroovyMAME64 version: https://www.mediafire.com/?su6lywrvus80z22
GroovyMAME64 arcade-only version: https://www.mediafire.com/?y7di2i0yqc8qbb9
edit: 32bit executables
GroovyMAME32 D3D9ex version: http://www.mediafire.com/?crq4a11aicoxoc9
GroovyMAME32 D3D9ex arcade-only version: http://www.mediafire.com/?h2vh7ylnqfxdxf5
GroovyMAME32 version: http://www.mediafire.com/?rbam2n26p52pci7
GroovyMAME32 arcade-only version: http://www.mediafire.com/?y7di2i0yqc8qbb9
any chance of a alpha 6 with MKChamp's suppression patch ? haven't had good luck compiling newer builds
thanks
keropi
« Reply #266 on: January 12, 2017, 03:37:36 am »
peterson65 which version you need?
mdd45
« Reply #267 on: January 12, 2017, 04:59:20 am »
I'm indeed using a sony crt with rgb scart. So no 240p with a 15khz on system-24 games.... :-(  thanks for the info.
peterson65
« Reply #268 on: January 12, 2017, 05:39:00 am »
thanks
« Reply #269 on: January 12, 2017, 09:43:57 am »
You can certainly force those games to ran at 240p if that's what you want (it will look like ass).
haynor666
  • retro maniac
« Reply #270 on: January 12, 2017, 11:06:06 am »
I force those games at 496x496 (stretched vertically).
keropi
peterson65
cbcduna
  • Last login:January 28, 2017, 04:46:35 pm
« Reply #273 on: January 14, 2017, 09:49:39 am »
Hi Keropi,
is possible upload the GroovyMAME64 D3D9ex version full?
Thanks in advance....
keropi
cbcduna
« Reply #275 on: January 14, 2017, 12:46:12 pm »
Very thanks mate!!!
bent98
  • Hyperspin Moderator
« Reply #276 on: January 15, 2017, 10:52:13 am »
I tried both DX and regular builds and my trackball and spinner do not work. I of course did enable them in the mame.ini. Helllllllllp
« Reply #277 on: January 16, 2017, 10:37:39 am »
Please provide a full log when reporting issues.
bent98
« Reply #278 on: January 16, 2017, 11:45:41 am »
Here you go. included mam.ini and rom log
« Reply #279 on: January 16, 2017, 12:17:01 pm »
SwitchRes: v0.016_alpha5
