Author Topic: XIN-MO for PS3 (Wired for PC)  (Read 1713 times)
OtakuArcade
  • Last login:January 17, 2017, 02:13:45 am
« on: August 02, 2016, 06:38:42 pm »
Hi All,
I have built a bartop arcade machine that is wired up and all working swell, however I recently discovered that the Xin-Mo can also work for the Playstation 3, is it possible for me to just unplug the USB and plug it into the PS3 and vice versa without issues, or is the wiring different?
The idea of playing Tekken Tag Two sounds amazing.
Cheers,
OA
thomas_surles
Re: XIN-MO for PS3 (Wired for PC)
« Reply #1 on: August 02, 2016, 07:03:13 pm »
Yes. But it will depend on your button layout and how you wired it. Like when I wired mine I don't ntsc care which input went to which button because I could just remap the buttons how I wanted in the emulatorso. Also I used joy to key so it didn't really matter. So you need to figure out which input goes to which button on a ps3 gamepads. I can't remember so I can't tell you what is x or triangle and whatever.
