Author Topic: 24" VGA Monitor that can adjust Horizontal and Vertical size  (Read 1171 times)
actman
  • Last login:April 18, 2024, 12:17:27 pm
All the new 24" monitors I have looked at will not allow adjustment for Horizontal and Vertical size ( expand the screen in and out)
They only seem to have H and V position (moves screen to right left or up or down)
Does anyone know a new model that would have that feature? It use too be common in the older monitors to have that adjustment option.
Re: 24" VGA Monitor that can adjust Horizontal and Vertical size
« Reply #1 on: July 28, 2016, 10:33:26 am »
I know CRTs that that used to be able to do that, but I don't think I've ever seen an LCD that allows you to do that particular feature. Certainly not widescreen ones either.
actman
« Reply #2 on: July 28, 2016, 11:01:19 am »
Yes I think you are right. They are controlled by a chip now and it auto adjusts. Thanks
southpaw13
  • Last login:August 17, 2025, 03:18:15 pm
  • Whatever!
« Reply #3 on: July 30, 2016, 02:05:17 pm »
I think you can still do it through software.  Video driver software.
