Author Topic: Usb encoder zero delay questions  (Read 2906 times)
SAVAGExMLGPRO
  • Last login:September 18, 2018, 08:42:34 pm
  • Check out my first machine build!
« on: July 22, 2016, 09:34:13 pm »
https://www.amazon.com/Reyann-Arcade-Encoder-Joystick-Fighting/dp/B00UUROWWK/ref=sr_1_1?s=electronics&ie=UTF8&qid=1469237569&sr=1-1&keywords=usb+encoder+zero+delay I want to purchase this for my cab, and hook them up to my X-arcade buttons. Would these work perfectly fine?
  • Last login:November 13, 2025, 01:36:49 am
Re: Usb encoder zero delay questions
« Reply #1 on: July 22, 2016, 09:56:48 pm »
There are better quality options out there,  but it should work.
SAVAGExMLGPRO
« Reply #2 on: July 22, 2016, 10:00:40 pm »
Is there a certain button to go back to the home screen of the retropie? Ive been using a xbox one controller for the time being and you use the start and select button to back out.
« Reply #3 on: July 22, 2016, 10:01:32 pm »
Dunno, don't use Retropie
SAVAGExMLGPRO
« Reply #4 on: July 22, 2016, 10:05:43 pm »
Oh ok, thank you anyways!
« Reply #5 on: July 22, 2016, 10:08:44 pm »
I would assume Retropie is configurable. Personally, I only use keyboard encoders in my projects.
monkeybomb
  • PM me to find out how to get a custom title like mine!
  • Last login:January 03, 2018, 07:16:29 pm
« Reply #6 on: July 22, 2016, 11:03:17 pm »
There won't be a specific button, but as soon as you boot retropi with that plugged in, retropi will ask how you want the buttons asigned.   Having said that, I thought the xarcade would be fine with retropi. Am I wrong?
SAVAGExMLGPRO
« Reply #7 on: July 22, 2016, 11:11:50 pm »
No clue yet, I havent bought the encoder to test it. Once that is bought ill let you know!
1
monkeybomb
« Reply #8 on: July 22, 2016, 11:35:22 pm »
I was referring to the x-arcade ecoder.  I guess I assumed you had one since you have the buttons, but in hindsight that was probably not the correct assumption.
Titchgamer
« Reply #9 on: July 23, 2016, 04:50:36 am »
Retro pie allows you to configure each controller/keyboard etc individually so whichever you use you can navigate the menus.
If I recall its B button to go back while in menu's and start and select to quit game.
SAVAGExMLGPRO
« Reply #10 on: July 23, 2016, 01:53:43 pm »
Yes, but i was wondering with the encoder i listed, is a specific button to go back. But if you were to check the encoder, what would be the start and select button? I dont remember ever seeing the start and select button when i configed the raspberry pi the first time.
southpaw13
  • Last login:August 17, 2025, 03:18:15 pm
  • Whatever!
« Reply #11 on: July 23, 2016, 02:10:20 pm »
I had to configure a hot button in Retropie for one of the buttons hooked up to my zero delay.  After messing around with the config files, I am now able to press player 1 and player 2 to exit a game.  Anything is possible with Retropie, it just takes time and patience to figure it out.  There is really no plug and play option.
SAVAGExMLGPRO
« Reply #12 on: July 23, 2016, 02:24:31 pm »
How did you do that exactly?
southpaw13
  • Whatever!
« Reply #13 on: July 25, 2016, 03:11:28 pm »
Somewhere in the retroarch config section.  I would try to search the Retropie forum.  I seem to find a lot of difficult programming answers there.
