Author Topic: HAPP 3" Illuminated Trackball Problems  (Read 1784 times)
Lamaman1971
  • Last login:June 20, 2024, 01:44:56 pm
« on: July 19, 2016, 11:53:21 am »
Hi Folks, I "thought" my control panel build was complete but Im having problems with my 3" HAPP trackball sticking. Its new (although its been in a box for ~9 months) and seems to stick when it get warm (as it will as its illuminated). Has anyone seen this before? Ive slackend off the screws attaching it to its plate which helps a little - but its still really bloody annoying.
Anyone got any ideas? Is it me or is it the trackball?
Titchgamer
Re: HAPP 3" Illuminated Trackball Problems
« Reply #1 on: July 19, 2016, 12:47:58 pm »
Ive never had a Happ but some need "breaking in" maybe this is the case with yours?
surface tension
  • Last login:July 01, 2018, 08:45:48 am
  • feel the tension...
    • surface tension tables
« Reply #2 on: July 20, 2016, 08:03:11 am »
I used to see this regularly with 2.1/4", but not so much these days. The trackballs had a 'lumpy' feel to the bearings as you rolled them.
Here's my guide if you wanted to fix it...
http://surface-tension.net/blog/fixing-a-sticky-happ-trackball/
