Author Topic: Raspberry Pi audio problem  (Read 2651 times)
SAVAGExMLGPRO
  • Last login:September 18, 2018, 08:42:34 pm
  • Check out my first machine build!
« on: July 16, 2016, 11:24:43 pm »
I have some speakers i'd like to plug into my Raspberry Pi. I'm using a hdmi to support video to the tv but it also carries the audio too. Can I use a usb soundcard with a audio jack and mic jack on it? Will it work exactly the way it would if there was a 3.5mm headphone jack?
https://www.google.com/express/product/2799216556623517124_2306321428961959764_6136318?mall=Texas&directCheckout=1
Link for example
Slippyblade
Re: Raspberry Pi audio problem
« Reply #1 on: July 16, 2016, 11:32:34 pm »
Yeah, no problem.  I think you might have to twiddle the config.txt though.  It's been a while since I was in the guts, but that's how I did it.
05SRT4
  • Check out my Pow Pow
« Reply #2 on: July 17, 2016, 01:56:32 am »
what Pi are you using? I thought most had a jack already.
Here are some instructions for configuring it.
https://www.raspberrypi.org/documentation/configuration/audio-config.md
Slippyblade
« Reply #3 on: July 18, 2016, 12:51:05 pm »
Onboard audio jack tends to be very noisy.  Going USB is far better.
SAVAGExMLGPRO
« Reply #4 on: July 21, 2016, 07:06:13 pm »
Im using the Raspberry Pi 3. It does have a jack but when i plug speakers into it nothing comes out. Only comes out through the HDMI, ig ill have to configurate it! Thank you for the link!!
The link i sent for the usb soundcard would work though? Would i still have to configure it if i used that?
