Author Topic: Removing spray paint blotch on monitor surface  (Read 1367 times)
ppv
  • Last login:October 16, 2020, 03:08:56 pm
  • The cheap@ss gamer
« on: July 16, 2016, 09:32:47 am »
Hey!
I have a silver paint blotch on my lcd monitor screen that I would like to remove, without harming it... What would you recommend?
Doing arcades, the cheap@ss way!
First Project : ttp://forum.arcadecontrols.com/index.php/topic,151071.0.html
Next one : The Token Muncher [urlhttp://forum.arcadecontrols.com/index.php/topic,135417.0.html[/url]
burn_654
  • Last login:April 29, 2025, 04:25:44 pm
Re: Removing spray paint blotch on monitor surface
« Reply #1 on: July 16, 2016, 12:49:49 pm »
I feel like maybe a little dab of goo gone might be your best bet - I used it to clean up a little bit of spraypaint overspray with my car (was painting over a scratch and a few drops went on some trim.) It worked well there, didn't scratch or harm the trim under it but lifted the drops. I would double check that it's gonna be safe for the monitor glass though - I've used that stuff on windows but only ever used a little water on monitors as they usually have a protective coating to worry about.
vinegar
  • Last login:August 12, 2017, 09:07:18 pm
  • ID/hardware hacker
« Reply #2 on: July 17, 2016, 03:33:57 pm »
spray paint is full of solvents, the antiglare coating on the panel is likely already damaged.  the AG on some panels is a film which can be removed entirely, but it's not an easy operation.  there's a contingent of PC modders who hate the haze AG film has, so there's lots of guides out there on doing it.
« Last Edit: July 17, 2016, 04:40:21 pm by vinegar »
  • Last login:Yesterday at 11:17:30 pm
« Reply #3 on: July 17, 2016, 05:19:13 pm »
Lighter fluid?
ppv
« Reply #4 on: July 18, 2016, 07:14:19 am »
I'll Try it on a spare 19". Thankfully it is a small blotch...
