Author Topic: Atari Video Music - Needs power supply  (Read 9829 times)
acvieluf
  • Last login:February 10, 2026, 08:01:11 pm
« on: July 04, 2016, 09:52:02 pm »
Hey all, i am waiting on some design work and parts for my mame cab, and thought i'd get some advice from you all.
I have had an Atari Video Music unit for a long time now, and it's always had it's "wall wart" power adapter chopped off.  The original runs 16.6v 100mA AC power.  I have found a wall wart adapter that runs that in DC power, but that's it.
I know i can run different voltages and mA, but i don't know which one can be more, and which one can be less.
Here's a YT clip, if you've never seen an Atari Video Music:
These are notoriously susceptible to static and electrical damage.  For all i know, it's a dead box.  But i'd still like to try.
Any suggestions? (preferably cheap, as i don't want to throw money away on something that can't work)
chopperthedog
  • Last login:Today at 12:28:22 pm
Re: Atari Video Music - Needs power supply
« Reply #1 on: July 04, 2016, 09:57:18 pm »
Old Peavey rack gear ran on 16v ac. bet they're cheap on amazon.
good day.
  • Last login:February 12, 2026, 03:35:47 am
« Reply #2 on: July 04, 2016, 10:04:17 pm »
I know their website leaves a LOT to be desired, but I'd contact these guys if I were you:
http://best-electronics-ca.com/
« Reply #3 on: July 05, 2016, 01:20:08 pm »
100mA?  Can that be correct?
  • Last login:February 11, 2026, 07:46:44 pm
« Reply #4 on: July 06, 2016, 12:02:43 am »
Huh.... I suppose it could be... Atari did some weird stuff with power back in the day.
I was thinking that Ben Heck did an Atari video project a while back... maybe there is some info on his site?
Btw.... we totally want videos when it's working.  ;)
acvieluf
« Reply #5 on: July 06, 2016, 08:49:28 am »
Yep. Here's a close-up of an adapter.
Sent from my Atari 2600
acvieluf
« Reply #6 on: July 06, 2016, 08:51:15 am »
Yeah, that was from January, which is awesome, cause I had never seen it before until I was looking things up for this post! It's awesome, but...he doesn't have to deal with the problem of not even HAVING an adapter. So thats step one, for me.
« Reply #7 on: July 06, 2016, 12:04:56 pm »
Ok, perhaps a roundabout solution.  I got a email about a DIY benchtop power supply project:
http://www.instructables.com/id/Adjustable-High-Current-Lab-SMPS-Out-of-a-Standard/
Maybe you can gleem enough knowledge out of it to rig up a 16.6v 100mA  power supply.
  • Last login:Yesterday at 09:07:51 am
« Reply #8 on: July 06, 2016, 12:26:05 pm »
I've got a couple of weird AC/AC power supplies laying around.  I'll check my pile this evening.
acvieluf
« Reply #9 on: July 06, 2016, 12:38:31 pm »
Man, that would be AWESOME.
acvieluf
« Reply #10 on: July 06, 2016, 12:38:55 pm »
Thanks, I'll check that out when I get home!
acvieluf
« Reply #12 on: July 06, 2016, 12:57:46 pm »
AC to AC Wall Adapter Transformer 16 Volt @ 1000mA Black Straight 2.1mm Female Plug
Sorry for the dumb question, but is it the mA that I can "overshoot?" I did this once for an old NES, but couldn't remember if it was the voltage or the milliamps.
« Reply #13 on: July 06, 2016, 01:04:26 pm »
You want the voltage to be in the proper range and the amperage to be equal or greater than.  The device will pull as much juice as it needs.  Proper voltage will ensure that it cannot try to pull too much at once and thus fry something.
« Reply #14 on: July 06, 2016, 01:09:18 pm »
Take a look at the schematic:
http://www.atarimuseum.com/videogames/dedicated/videomusic/vm-sidea.jpg
You can bypass the AC adapter entirely and feed DC voltage to the test points on the board.  Looks like you need -9V (TP3), -5V (TP1), and +8V (TP2).  Playing with a 12V supply, some resistors, and an inverter circuit should coax all those out.
« Reply #15 on: July 06, 2016, 01:10:41 pm »
That's a thought too if it comes down to that.
« Reply #16 on: July 06, 2016, 01:33:17 pm »
^^This^^
The question really comes down to how flexible the device is in terms of voltage.  Most things will work with a volt or two in either direction.
acvieluf
« Reply #17 on: July 06, 2016, 04:19:07 pm »
Haha, I really appreciate the input. This project may take a LONG TIME to learn enough to do anything with, beyond the power adapter.
« Reply #18 on: July 06, 2016, 04:52:43 pm »
Look at the bottom of the page where it says POWER.  Basically what's happening there is 14V AC is being rectified into DC current, and then chopped into the three voltages you need.  The circuit board will have three posts sticking off of it where you can measure to make sure all the proper voltages are being fed to the rest of the device.  (these test points are there for diagnostics because these circuits run hot and parts burn out)
My proposal is that you ignore the AC part of this setup, and directly connect another power supply to those test points.
Anyway, I'm pretty sure I've got either a 12V or 14V transformer laying around.  It was yanked out of a stereo.
« Reply #19 on: July 06, 2016, 08:44:21 pm »
Look at what I got....
Feel comfortable wiring this up?
acvieluf
« Reply #20 on: July 06, 2016, 08:47:22 pm »
HAHA!  I definitely deserve that.  I can wire this up.  Even with this, i'd have questions.  :lol  But i can do it!
What do you want for it?
« Reply #21 on: July 06, 2016, 09:56:09 pm »
Free.  Send me your address and I'll mail it tomorrow morning.
acvieluf
« Reply #22 on: July 06, 2016, 10:23:22 pm »
Wow, thanks! Pm incoming!
« Reply #23 on: July 06, 2016, 11:32:34 pm »
That Jim is a classy guy. I tell you what, I'm sending you your stickers tomorrow.
« Reply #24 on: July 06, 2016, 11:46:42 pm »
He has his moments.
Btw.... I was thinking man, you should do a youtube channel of popular songs on the AVM, like people do with those floppy organs.  I would subscribe.
« Reply #25 on: July 07, 2016, 09:23:08 am »
Power supply is on its way to Canada.  The black and white wires are your AC input, the two blue wires are your 14V output.  I tested it and you should be good to go.
acvieluf
« Reply #26 on: July 07, 2016, 09:53:03 am »
He has his moments.
Hmmm....now that's an idea!
« Reply #27 on: August 03, 2016, 03:02:26 pm »
So.... transformer arrive?
« Reply #28 on: August 03, 2016, 11:37:08 pm »
Also I demand a video of this thing in action.
acvieluf
« Reply #29 on: August 04, 2016, 12:00:43 am »
It did!  I wasn't trying to be rude in not replying here yet.  I have been out of town off and on lately, but was planning on posting here when i got back to work on it this next week!
The TMNT magnets were awesome, what a sweet bonus!
Thanks, and i'll post a bit more when i get back.
acvieluf
« Reply #30 on: September 19, 2016, 10:13:13 pm »
So after the loooong delay, i was able to pick this back up.  It took me about an hour looking at the schematic, and the wiring to be confident enough to wire it up without blowing it up.  I connected it up, and viola!  No smoke or sparks!  Then i realized that the video output requires an RF adapter.  I have one kicking around, so the search is on.  Here's a pic to prove this little side project isn't dead.
Also, now that i'm sitting down with a little more time, thank you again, pbj, for the transformer and the magnets.  My 5 year old daughter (who loves ms. pac-man) nabbed your postcard before i saw it.  That took some swift "hey, look over there", type hiding. haha.
the x's and o's were a nice touch   :lol :lol
Locke141
  • Never grow up.
« Reply #31 on: September 21, 2016, 06:09:50 am »
« Reply #32 on: September 21, 2016, 11:30:53 am »
Yeah, despite all his diagnostic toosl, he just shotgun replaces a bunch of parts until it works IIRC.
« Reply #33 on: September 22, 2016, 11:27:14 pm »
Eh it's a million years old. That's probably what I would have done just to be on the safe side.  I have no clue why I'm defending Ben Heck.... I'm not exactly a fan.
I think acvieluf is trying to beat me on my slowness record.  We want vids man, pick up the pace.  ;)
acvieluf
« Reply #34 on: September 23, 2016, 07:45:00 am »
Haha, yes I'm aware I'm being slow. However, I have located an RF adapter, and should be back to testing it tomorrow. Although I think a video at this point will probably be just a blank screen. Just a hunch,  :dunno
So simmer down now.  :timebomb: :lol
« Last Edit: September 23, 2016, 07:46:37 am by acvieluf »
acvieluf
« Reply #35 on: September 25, 2016, 09:17:35 pm »
Welp, as promised, an action photo.
Looks like I'm going to NEED a multimeter. I was hoping to get lucky... : /
