Author Topic: Possible to hook this up to an encoder?  (Read 1912 times)
equlizer
  • Last login:November 17, 2019, 02:56:48 am
  • All your base are belong to us
« on: July 04, 2016, 12:41:02 am »
http://retroactivearcade.ca/led-2-trackball-for-60-in-1/
A local company (friend) is selling it but needs to know what each wire is what.  I want to hook it up to a kade encoder. :cheers:
  • Last login:Today at 12:13:02 am
Re: Possible to hook this up to an encoder?
« Reply #1 on: July 04, 2016, 03:49:00 am »
Here's a picture that shows the wires better.
Not sure about the pinout, but there are 6 wires like you'd expect on any trackball.
- 5v
- Ground
- X1 (data)
- X2 (data)
- Y1 (data)
- Y2 (data)
Red and black are probably 5v and ground.
Once you've confirmed that, the data lines are easy to sort out by moving only one axis at a time and swapping the data lines if the axis is moving the opposite direction expected. (i.e. if you roll the ball to the left and the cursor moves right, swap X1 and X2)
The only potential downside on using it with a KADE is that the lighting LEDs are almost certainly wired in parallel with the optical circuit IR LEDs.
The 4 IR LEDs and the lighting LEDs combined may draw more current than the KADE can supply.
   :dunno
EDIT: On second thought, it probably won't be a problem since Jon used an illuminated Sparkfun trackball (2:45) in this video.
« Last Edit: July 04, 2016, 04:07:51 am by PL1 »
equlizer
« Reply #2 on: February 05, 2017, 01:07:51 pm »
Very late reply.  So i purchased one and just wanted to make sure it will hook up to the kade using one of the profiles.  Which one do i need to use?  Thx
« Reply #3 on: February 05, 2017, 02:49:47 pm »
There are two Beta KADE firmwares that should work with the quadrature-waveform data lines from this trackball:
- Trackball to USB Gamepad Encoder
- Trackball to USB Mouse/Keyboard
If you don't see them at the bottom of the firmware list in Loader, select the menu item "Advanced -- Beta Version -- Receive Beta Updates".
