Author Topic: How do i stop hyperspin from auto starting on arcade  (Read 2831 times)
equlizer
  • Last login:November 17, 2019, 02:56:48 am
  • All your base are belong to us
« on: July 01, 2016, 09:24:55 pm »
Its been over a year since ive touched this machine and i want to use it as a regular pc for a while but hyperspin keeps launching and the wife doesn't know what to do.
Milky
  • Last login:February 22, 2022, 07:57:34 pm
Re: How do i stop hyperspin from auto starting on arcade
« Reply #1 on: July 01, 2016, 09:43:25 pm »
If HyperHQ is still on the machine there should be a place to uncheck the launch at startup option for hyperspin.  That should hopefully help!
05SRT4
  • Check out my Pow Pow
« Reply #2 on: July 01, 2016, 11:51:41 pm »
If using windows OS check to see if Hyperspin is in the start up folder. Do you remember how you initially got it to auto launch? Normally you need to tell it too.
equlizer
« Reply #3 on: July 02, 2016, 02:33:53 am »
i dont see anything in the startup folder or in sysconfig or hyperhq.  What would the setting be in hyperhq?  (i am not running the latest version)
Titchgamer
« Reply #4 on: July 02, 2016, 08:25:08 am »
Try going to start, click in the search bar and type msconfig then look in start up tab to see if it shows.
Be carefull not to disable anything else in there though!!
05SRT4
« Reply #5 on: July 02, 2016, 04:23:06 pm »
Worst case you could back up the Hyperspin folder to a flash drive then just delete it.
