Author Topic: Need help Identifying board  (Read 2612 times)
dylaninwv
  • Last login:October 09, 2019, 07:05:47 pm
« on: June 29, 2016, 02:18:40 pm »
Please see the below pic. I could use some help in identifying this board and it's manufacturer. This is from an old arcade machine, hooks up to the coin mech, and it sends the signals after it registers two quarters. Runs off of a 12vdc power supply.
  • Last login:Today at 06:22:50 pm
Re: Need help Identifying board
« Reply #1 on: June 29, 2016, 03:01:27 pm »
it's probably just an accumulator.
basically can be programmed for infinite coins per play when the game itself is only programmed for 1.
so if you want to drop 2 or 3 or 4 or 80 coins before a credit is issued, you'd use an accumulator.
specifically, i have no idea who makes it or how you'd reprogram it... likely you'd remove the brown chip and reprogram it.
you can try removing the top board from the bottom and see if there is a manufacturer or a part number on the backside.
jeremymtc
  • Last login:February 14, 2026, 05:36:37 am
« Reply #2 on: June 29, 2016, 05:34:02 pm »
A Google search for "Phase II Electronics" + "Arcade" brings up http://www.bobholland.com/phaseii/index2.htm
Though the page is very outdated, the list of services seems to jive with what you have [pcb design, arcade parts manufacture], and there's contact info at the bottom. Might be worth an email.
*edit* me@bobholland.com
« Last Edit: June 29, 2016, 05:38:01 pm by jeremymtc »
  • Last login:Today at 08:00:13 pm
« Reply #3 on: June 29, 2016, 05:46:45 pm »
That website is gold.
  • Bitches love Centipede
« Reply #4 on: June 29, 2016, 07:01:51 pm »
Page Updated July 18, 1996.
Wow.
%Bartop
Slippyblade
« Reply #5 on: June 29, 2016, 07:10:41 pm »
Holy crap.  I think MySpace puked on that guys front page.  He's even got the dripping blood horizontal rule on there.
« Reply #6 on: June 29, 2016, 10:07:45 pm »
i think (thought) OP was referring to this...which is not part of the original game board and is attached to the top of it.
ed12
« Reply #7 on: June 29, 2016, 11:22:08 pm »
it is a add on
holy ---steaming pile of meadow muffin--- that is 1 old gal chip
ed
« Reply #8 on: June 30, 2016, 02:08:30 am »
signetics. nuf said. they still around??
yep thats an old as hell micro controller.
dylaninwv
« Reply #9 on: June 30, 2016, 09:33:47 am »
This was inside of an old Standard Metal Typer. Power supply is a Radio Shack 12vdc power supply, and this controlled the release solenoid based on getting 2 quarters through the coin mech switch. So its not suprising on the age.
dylaninwv
« Reply #10 on: June 30, 2016, 10:31:57 am »
Thanks. I shot him an email. Assuming it doesn't go to an old MySpace server, maybe I'll get lucky...  ;D
« Reply #11 on: June 30, 2016, 11:19:26 am »
MySpace was way after 1996, dude....
« Reply #12 on: June 30, 2016, 04:47:28 pm »
"geocities" was the one i think people were thinking about.
dylaninwv
« Reply #13 on: July 05, 2016, 10:56:53 am »
Thank you JeremyMTC....interesting results....
I contacted the person listed on the website. His son replied back to me. Sadly, his father (the man who designed and built the board) passed away in 2011. He did recognize it, and was able to tell me what it was - it was part of an arcade-wide tracking system:
"My father's Money Tracking System worked as follows: let's say an arcade was filled with 50 games of all different types (like video games, crane games, etc.).  You would install a remote board in each game, like the one you have in your machine, and connect it to the coin switch.  If you look at the remote board, you'll see 2 "phone" type jacks marked "In" and "Out".  You would use those jacks to connect all of the 50 machines together, and then to a "Master", or "Main" unit, almost like a network you would see today.  Each remote board had it's own unique number to identify it on the network.  The main unit was usually back in the office, or somewhere similar.  This allowed the owners of the arcade to track, and record, at a glance exactly how much money each game was taking in, and how much money was being made overall."
Interesting, but of no use to me. If anyone would like it, let me know.
