Author Topic: How do you make a powercord?  (Read 1741 times)
crashdmj
  • Last login:August 26, 2003, 08:55:42 pm
  • Hulk smash!
    • Best webpage in the Universe!!
« on: January 17, 2004, 05:55:37 pm »
Hello, been awhile...
I have an arcade monitor that I'm not sure if it works or not, It has no powercord and I was wondering if there is an easy way to make one?
Derek
« Last Edit: January 17, 2004, 05:59:42 pm by crashdmj »
Generic Eric
Re:How do you make a powercord?
« Reply #1 on: January 17, 2004, 09:48:36 pm »
You can buy "electical cord" cable at your favorite hardware or lowes/home depot.  In the same aisle you should find the plug (that plugs in the wall) as well.
Ken Layton
  • Guru
  • Technician
« Reply #2 on: January 18, 2004, 02:26:10 am »
NEVER plug a monitor into the wall outlet unless you know for sure it has a switching power supply built-in and specifically says NO ISOLATION NEEDED. Nintendo Sanyo, Nintendo Sharp, and many Sega/Nanao monitors operate on 100 volts NOT 120 volts.
You can buy ready made monitor power cords from Wells-Gardner (www.wellsgardner.com) but you must call them and talk to a live person to order it.
