Author Topic: oops  (Read 3712 times)
  • Last login:December 11, 2025, 11:01:31 pm
oops
« on: June 21, 2016, 10:35:42 pm »
wrong hard drive...
mahkeymike
  • Last login:November 21, 2025, 04:40:35 pm
Re: oops
« Reply #1 on: June 22, 2016, 07:19:51 am »
How far did it get? I always wondered how much security other coin-op companys implemented into there software/games. Also wondered if they used similar hardware aswell.
Re: oops
« Reply #2 on: June 23, 2016, 02:26:23 pm »
the BBHP (big buck hunter pro) has a serial IO board it checks for first before even it checks for a security key (USB HASP from currently known as Vector Capital's "SafeNet" (formerly known as Aladdin Knowledge Systems))
EDIT: oops apparently safenet is now "GEMALTO" man these guy change names more often than HP...I mean Agilent...er...I mean Keysight.
It gets to the IO board check and stops with a screen "CONNECT IO BOARD" which is the same you get when you have a legit computer being bench tested. Kinda weird that BBHP prioritizes the chack for the IO board before checking security.
I didn't have a keyboard attached at the time... but you can press escape to view the linux boot process on the BBHP. It's good for seeing if it's hanging up on something.
much like the Golden tee Nighthawk motherboards and the Merit boards, they run linux with just the driver set needed for the boards they use. fortunately there is a wider variance of board you can use with BBHP. basically any motherboard with a nvidia 6100 chipset and a realtek ALC662 or 655 sound chip will work straight out of the box with no mods. there was even the addition of a few dell motherboards, but they are pretty hard to nail down since they (like intel) recycle the same model numbers over and over again.
« Last Edit: June 23, 2016, 02:30:14 pm by lilshawn »
