Author Topic: Can UltraStik's UltraMap Program Remap Buttons?  (Read 1438 times)
DrakeTungsten
  • Last login:August 14, 2022, 06:36:45 pm
  • I effed with the wrong person!
    • No Quarter - a basic FE, WIP
« on: June 15, 2016, 12:42:07 am »
I have two UltraStik 360s and I am thinking about getting the harnesses for them which connect buttons to the stick, and then the joystick + buttons are presented to the OS as a gamepad. I haven't found anything which says that you can program the stick so that you can specify which button is gamepad 1 button 1, which button is gamepad 1 button 2, etc...
Can Ultramap do this once the harnesses are attached? I don't see this functionality when I run it with the sticks connected, but there's a chance this functionality isn't present just because I don't have the harness.
GeoMan
  • Last login:January 01, 2026, 09:49:39 am
Re: Can UltraStik's UltraMap Program Remap Buttons?
« Reply #1 on: June 17, 2016, 06:33:57 pm »
You can't change them using Ultramap. But you can use a program like Xpadder to map different keyboard keystrokes to them.
« Last Edit: June 17, 2016, 06:35:29 pm by GeoMan »
DrakeTungsten
« Reply #2 on: June 17, 2016, 07:56:55 pm »
Thanks. I'll probably end up getting them anyway, and use AHK if I want to convert a gamepad button to a keyboard key.
