Author Topic: Advice : Best Joystick for a 3/4 bottom mount - no routing  (Read 1884 times)
Lamaman1971
  • Last login:February 06, 2026, 11:21:46 am
« on: June 13, 2016, 01:24:30 pm »
Hi Everyone - Im looking for some suggestions regarding a bottom mount joystick. Its underneath 3/4 wood so needs to be a longer shaft - any thoughts? - I dont want to route.
Re: Advice : Best Joystick for a 3/4 bottom mount - no routing
« Reply #1 on: June 13, 2016, 01:39:05 pm »
What type of games? General?  I liked the Happ Supers I played on at Zapcon.
Lamaman1971
« Reply #2 on: June 13, 2016, 01:44:04 pm »
Yeah, nothing specific - general gaming etc.
« Reply #3 on: June 13, 2016, 01:47:28 pm »
you can also get Zippyys which are knockoff Semitsu LS-32's with the long shaft for wooden panels at a great price from Randy at GGG.
  • Last login:February 22, 2026, 06:49:16 pm
« Reply #4 on: June 13, 2016, 02:59:59 pm »
IL eurostick
JDFan
« Reply #5 on: June 13, 2016, 06:15:39 pm »
Is the CP already made ? Reason for asking is if it is not you could always make the CP using 2 pieces of wood (1 - 1/2" and 1 - 1/4" thickness) to create the 3/4" CP and then that way you could cut out a piece of the 1/2" and just use the 1/4" piece for mounting to rather than mount 3/4" deep (easy to cut out a rectangle using a jigsaw and then place the 1/4" panel over that with just the hole for the joystick handle) glue the two pieces together and let dry and not have to route.
I would suggest this so that the feel of the joystick is correct ( the longer the handle the more the top of the stick has to be moved )
Mr. Peabody
  • Last login:February 12, 2026, 12:32:17 am
« Reply #6 on: June 21, 2016, 04:49:32 pm »
Suzo 500. It might be my favorite 8-way, smooth in all regards. You might need to make your hole a little bigger.
https://www.google.com/?gws_rd=ssl#q=suzo+500
« Last Edit: June 21, 2016, 04:51:17 pm by Mr. Peabody »
« Reply #7 on: June 21, 2016, 05:20:16 pm »
Ball top or Bat Top?
