Author Topic: Injustice Gods Among Us Arcade Build  (Read 12602 times)
thestobbster
  • Last login:February 16, 2021, 10:44:01 pm
« on: May 26, 2016, 10:28:08 pm »
Well today I saw on YouTube  that someone built an Injustice themed cabinet for their PS3. My PS3 is in the basement collecting dust so I decided do something to get it back in to use. I wanted to make sure that it still worked so I hooked it up to my Bartop. Well the joystick worked but I did not have enough buttons to play the game. I have 6 buttons and it looks like I need 8. Today I started planning to build a new cabinet to put my PS3 inside. I downloaded the plans for a Midway Mortal Kombat cabinet. It looks pretty simple. I have built 3 custom Mame cabinets and 2 bartops so this is nothing new. It is time to do another arcade project. I started working on the artwork tonight. I tried to find the same graphics that were used for a cabinet that I saw on YouTube but was unsuccessful. The next logical hing to do was search Google Images and do my own design for this one. Here is what I came up with so far... I am thinking about illuminating the Never Realms logos on the top sides of the cabinet.
« Last Edit: May 27, 2016, 02:21:26 pm by thestobbster »
THeSToBBSTeR
Re: Injustice Gods Among Us Arcade Build
« Reply #1 on: May 27, 2016, 08:16:00 am »
you dont need 8 to play, you can hit button combos
thestobbster
« Reply #2 on: May 27, 2016, 11:11:20 am »
Thank you, That is good information. At least I can play with 6 on the bartop until I get the cabinet built. I decided to do a mock up to see what it's going to look like when completed with the graphics. I just finished the left side of the cabinet.
THeSToBBSTeR
thestobbster
« Reply #3 on: May 27, 2016, 12:07:22 pm »
Well here is the right side. Can't wait to build the cab and order the artwork for this Baby!
THeSToBBSTeR
« Reply #4 on: May 27, 2016, 02:59:42 pm »
I thought I might make a rare artwork forum appearance on this one.  ;)
My 2 cents....  If you are trying to replicate the look and feel of a Midway fighting cab (you should!  they are awesome!) you have a few things wrong.
Remember, a real cab is all about branding, so the front and sides of the control panel box are typically a solid color with either the publisher logo (the sides) or the game logo (the front).  Also the control panel is a bit busy with the stage render being used.  I would suggest changing that to a simple repeating pattern... you can probably find something suitable on the game's website.  Keep the graphics around the buttons though, those are great.
Hope that helps... it could be a really impressive cabinet with what you have so far.
ppv
  • Last login:October 16, 2020, 03:08:56 pm
  • The cheap@ss gamer
« Reply #5 on: May 27, 2016, 08:22:01 pm »
Your side art is cool, but I would fade the differents graphics together... those jarring transitiosn makes it looks a bit odd, imho.
Doing arcades, the cheap@ss way!
First Project : ttp://forum.arcadecontrols.com/index.php/topic,151071.0.html
Next one : The Token Muncher [urlhttp://forum.arcadecontrols.com/index.php/topic,135417.0.html[/url]
thestobbster
« Reply #6 on: May 27, 2016, 08:43:11 pm »
Well I went back to the drawing board and came up with this design... I hope I am moving in the right direction. Thanks for the input guys. I want this to be spot on!
THeSToBBSTeR
Slippyblade
« Reply #7 on: May 27, 2016, 08:54:50 pm »
I like the update much better.  Cleaner.  I'd still only do 6 buttons though.  Button 7 and 8 are simply to make it easier to do multi-button moves on a gamepad.
thestobbster
« Reply #8 on: May 27, 2016, 10:31:53 pm »
Yes I think that overall the whole thing ties together much better.
THeSToBBSTeR
thestobbster
« Reply #9 on: May 28, 2016, 12:14:41 am »
« Last Edit: May 28, 2016, 12:26:45 am by thestobbster »
THeSToBBSTeR
thestobbster
« Reply #10 on: May 28, 2016, 01:34:52 pm »
On most games there is usually an instruction card. Since I plan to use my PS3 in the cabinet and I plan to play other games from time to time, I created this sticker to be place under the display.
THeSToBBSTeR
n3wt0n
« Reply #11 on: May 28, 2016, 03:01:17 pm »
It looks like the circle layer around the joystick is covering the 4-8 way text at the top on both player one and player two. Other than that it looks good to me.
rablack97
« Reply #12 on: May 29, 2016, 03:26:42 pm »
Dude, don't listen to the 6 button guys on this on, as Malenko and Slippy are respected members  :notworthy:, but don't go with 6 buttons on a console based arcade build.
I went with 8 and i couldn't of been happier with the decision.  There is no point in contorting your fingers to do button combos if 7 and 8 and can pull it off with a single button press.
Check out the MKX build in my sig line if you want some more ideas, art looks good  :applaud: :applaud: :applaud:
Needs white t-molding, black, or chrome-black, red (not so much)
« Last Edit: May 29, 2016, 04:39:25 pm by rablack97 »
« Reply #13 on: May 29, 2016, 04:09:11 pm »
Looks fine, but I'm not a big fan  of the gigantic-looking PS3.
Sent from my SM-G386T using Tapatalk
Slippyblade
« Reply #14 on: May 30, 2016, 04:21:46 pm »
Huh?  Malenko, sure.  Me?  Oh please.
rablack97
« Reply #15 on: May 31, 2016, 12:11:10 am »
You've been know to give valid inputs, I just wanted to ensure, the no disrespect clause was in full effect for the both of you. :applaud:
thestobbster
« Reply #16 on: June 01, 2016, 12:21:11 pm »
Took out the large PS3 logo.
« Last Edit: June 01, 2016, 12:48:52 pm by thestobbster »
THeSToBBSTeR
« Reply #17 on: June 01, 2016, 12:26:54 pm »
LIES!
Anyfart, I didnt mean to imply he should only use 6 buttons on this build, just that MK9/MKX/Injustice  do not require 8 buttons to play   :cheers:
« Reply #18 on: June 01, 2016, 02:29:50 pm »
Not sure that' s better.
Do you really need anything that says PS3 anywhere? To me, it breaks the illusion of it being an arcade cab. It's like putting "Intel Inside" on a regular MAME cab. Let the game speak for itself, in my opinion.
Other than that, nice job. :cheers:
« Reply #19 on: June 01, 2016, 03:06:52 pm »
Do a moves bezel, since you're going to have to have a widescreen in there might as well make the unused real estate count for something.
Also rablack's MK cab is the widest that a cab can be and not suck, keep that in mind.
« Reply #20 on: June 01, 2016, 03:33:29 pm »
YourMKArcadeSource built an Injustice cab a while back.
Here it is in action:
He had 8 buttons and it looked great.
DeL
« Last Edit: June 01, 2016, 03:35:13 pm by DeLuSioNal29 »
rablack97
« Reply #21 on: June 01, 2016, 11:27:44 pm »
+1 with the homie on this one pay homage to the game not the console.  I used an xboxone, with no xb1 verbiages or logo's.
Yot, this cab is deceiving, its not a injustice dedicated, its an injustice themed cab, so i think more than one game will be played on it, which is why PS3 is being displayed.
LIES!
You can play tempest w/o a spinner too, but its not as fun  >:D .  You can play CAVE games on a wide screen, but it looks better on a vertical.  The Dallas Cowboy art looked better w/o the marquee.  Do you see where I'm going with this?    :cheers:
DeL
Cause the man understands how fighting games are supposed to be played......
(Right on, shiiii, he didn't trip, sucka payed the eight ball like a mutha)
MK3FAN
« Reply #22 on: June 03, 2016, 08:07:36 am »
Nice job so far OP! Looking great. If you are going to use an LED/LCD, I modified my bezel for one. You can have it if you want it...
http://www.mediafire.com/download/lhw8g698xc88wpu/Injustice+LED+LCD+Bezel.zip
MK3FAN
« Reply #23 on: June 03, 2016, 08:13:34 am »
Not to hijack the OP's thread, but I actually ended up installing a 27" LED monitor in all three of my custom cabs and they look AMAZING so I had to redesign the bezels...
« Last Edit: June 03, 2016, 08:15:35 am by MK3FAN »
rablack97
« Reply #24 on: June 03, 2016, 12:45:45 pm »
Did you ever update the MKX Bezel, and would you mind releasing that one too?
MK3FAN
« Reply #25 on: June 03, 2016, 03:26:35 pm »
After the Kombat Pack 2 was released, there were too many characters to fit them all on one bezel unless I included ONLY the finishing moves, and they all have a LOT of them too. The most up to date one I have only features the original characters that were released with the game before any of the Kombat Packs were released...
http://www.mediafire.com/download/qijy3nae4tynulk/MKX+Bezel+Final.zip
thestobbster
« Reply #26 on: June 03, 2016, 11:32:31 pm »
The Bezel will be a nice addition to my cabinet.. Thanks for the link!  :applaud:
THeSToBBSTeR
vwalbridge
« Reply #27 on: June 08, 2016, 04:19:56 pm »
Injustice 2 just announced. Start over.   ;)
« Reply #28 on: June 08, 2016, 05:25:51 pm »
Will the new one have PITA controls for the PC version too?   :banghead:
DeL
« Reply #29 on: June 08, 2016, 05:33:38 pm »
DeL
its cute that you think they'll release it for PC
