Author Topic: HDMI -> VGA -> SLG Flicker  (Read 1707 times)
Charlie97L
  • Last login:July 03, 2017, 03:35:56 pm
« on: May 25, 2016, 10:56:25 am »
I'm getting some flickering while connecting my Pi to an HDMI VGA converter then running it through a SLG.  It's only when the SLG is on.  Is this normal for a SLG?
nitrogen_widget
  • Last login:September 12, 2025, 07:07:08 pm
Re: HDMI -> VGA -> SLG Flicker
« Reply #1 on: May 26, 2016, 02:30:41 pm »
Do you have a powered hdmi to vga adaptor?
I do notice slight flicker & dimming of the picture using the same setup as you with my rpi2.
I think it has to do with signal strength coming off the hdmi convertor.
I'm going to try the Gert VGA and see how the works.
You can also try a different brand of hdmi>vga adaptor.
Charlie97L
« Reply #2 on: May 26, 2016, 02:37:06 pm »
Yes it is powered.  I tried it unpowered and powered and there was no difference.
Charlie97L
« Reply #3 on: May 26, 2016, 09:42:38 pm »
I ordered another one to try.  If that doesn't work I'll suck it up and get the HDFury Nano.
Charlie97L
« Reply #4 on: May 28, 2016, 06:23:15 pm »
ditched it entirely for the crt-pi shader.  once configured, looks amazing.
the new converter didn't even work at all with the SLG.
