Author Topic: Sanwa Joystick  (Read 2863 times)
shitoken
  • Last login:May 30, 2025, 07:41:27 am
Sanwa Joystick
« on: May 20, 2016, 09:48:56 pm »
Hi to all friends
This is my first post , if this is the wrong please admin help to transfer to right post
I am using ultimate I/O encoder and recently I have replaced new 1p & 2p Sanwa Joysticks. But now it seems I don't have right  for P1 & left for P2 and keyboard also stop responding and admins buttons not responding , therefore I am unable to exit hyperspin.
I did not change any setting in ipac or anywhere else.
What went wrong or I missed setting something?
Appreciate if anyone could give some bright light.
  • Last login:January 29, 2026, 12:04:48 pm
Re: Sanwa Joystick
« Reply #1 on: May 22, 2016, 11:42:11 am »
Some sellers of the Sanwa JLF joysticks will try to save money by including a generic wiring harness not meant for it.
It will work perfectly fine, but the colors of the wires are wrong  (black isn't ground).
Ground (the black wire) is the one closest to the edge of the PCB.
I don't think I've ever seen anyone on these boards mention ever getting a faulty switch, so it's probably not that.
EDIT:  This pic shows the correct wiring harness with the black ground wire at the top.
« Last Edit: May 22, 2016, 11:48:43 am by BadMouth »
shitoken
Re: Sanwa Joystick
« Reply #2 on: May 31, 2016, 07:58:49 am »
Seller have already given me the wirings information as below and it is good now. Thank you
Up orange
Dn red
Left yellow
Right green
Ground black
Tapatalk を使用して私の A0001 から送信
