Author Topic: Donkey Kong Restoration  (Read 1044 times)
ksnook
  • Last login:May 30, 2018, 05:07:37 pm
« on: May 16, 2016, 08:29:31 pm »
I just purchased a non-working Donkey Kong on craigslist and need some assistance from the wise ones. It has the two board Nintendo of America setup. On the main board the cpu was missing. I've purchased one from Mike's Arcade, do I just plug the new cpu in and go? Also there were two ceramic capacitor disks that were loose on one side. All I can read on them is 103Z. They are in locations c140 and c154 on the board. Can I just use any 50v 103Z or does it have to be marked 10 or 22 like the others?
Thanks for any help you might be able to give.
Kevin
lilshawn
  • Last login:November 26, 2025, 03:26:23 pm
Re: Donkey Kong Restoration
« Reply #1 on: May 18, 2016, 02:57:24 pm »
likely they are just bypass caps or power smoothing caps.
either way, the voltage won't make much difference. they would be 0.01 uf 50 volts (according to the code) but you could use a larger voltage if that's all you had.
ceramic caps don't really go bad, so if you can solder them back solid again, they'll be good to go.
as far as your CPU goes... hard to tell... it's always a crap shoot if you inherit someone else's machine. you never know what they've done to it or why it's CPU is missing.
it's possible someone just stole it to fix another machine, in which case... it should be good to go with a new one. otherwise...  :dunno
Slippyblade
« Reply #2 on: May 18, 2016, 03:37:48 pm »
This has me interested.  Keep us informed how it goes.
« Reply #3 on: May 18, 2016, 03:47:15 pm »
Kevin
Kudos to you Kevin, most people's first post is about some ill advised arcade playin' furniture they plan on building.  Your jumping straight in to fixing original hardware, good luck and let us know how it goes!
zinger
  • Last login:February 25, 2019, 05:09:31 pm
  • There's a Donkey Kong Kill Screen coming up!
« Reply #4 on: May 23, 2016, 12:59:06 am »
What's the model number of the PCBs? I'm assuming TKG4 but I couldn't find C140 or C154 in the TKG4 CPU or video schematics. Its sort of like "Where's Waldo?".
