Author Topic: Revolution X Gun recoil and MameHooker  (Read 4406 times)
Brian74
  • Yep... I built that!!
« on: May 10, 2016, 10:40:33 pm »
I got three Rev X guns off ebay. The plan is to get the recoil to work with mame and whatever other emus I can. I seen retro repairs video and have asked for help in the parts I need to make the recoil work. That was a few weeks ago and still have not heard back. I have read a few thread and watched videos, but none list the parts you need. In retro repairs video, he says he is using a relay and a pac-drive to fire the recoil. I have the pac-drive but dont know what relay to get. I have a 24v power supply I plan to use. Any help would be great!!
Endprodukt
  • Last login:February 23, 2026, 12:12:40 pm
Re: Revolution X Gun recoil and MameHooker
« Reply #1 on: May 11, 2016, 06:50:45 am »
Any relais within the range of the power supply will work.
This for example: http://www.ebay.com/itm/5V-Four-4-Channel-Relay-Module-With-optocoupler-For-PIC-AVR-DSP-ARM-Arduino-8051-/201498785043?hash=item2eea437513:g:gKoAAOSw1DtXIdXL
You could also go solid state: http://www.ebay.com/itm/1pcs-5v-4-Channel-OMRON-SSR-G3MB-202P-Solid-State-Relay-Module-For-Arduino-/400985463153?hash=item5d5c989971:g:uOcAAOSw~gRVinY~
I'm using the first one.  The solid state board has a rating of 2A for each channel which is a little too close for me so I went with the mechanical one. You could of course use these: http://www.ebay.com/itm/24V-380V-40A-250V-SSR-40-DA-Solid-State-Relay-Module-3-32V-DC-To-AC-/201414937205?hash=item2ee5440a75:g:0MoAAOSwD0lUduWt
As for wiring... you can either switch power or ground. Each gun needs around 2A so be sure your power supply has enough power.
Endprodukt
« Reply #2 on: May 11, 2016, 01:16:36 pm »
Forget all that.
My relais started melting inside. They can't handle it. Also, you need a DC-DC solid state. This:
http://www.ebay.de/itm/ET-Solid-State-Relais-SSR-DC-DC-25A-3-32VDC-5-60-VDC-/201554624862?hash=item2eed97815e:g:rw0AAOSwud1XAVsc
Brian74
Endprodukt
« Reply #4 on: May 12, 2016, 09:16:26 am »
Relais won't work. Have to be DC/DC. These are DC/AC. Won't switch. That power supply is way overpowered but will work just fine.
Brian74
« Reply #5 on: May 14, 2016, 09:34:49 pm »
I ordered new relays and the power supply is adjustable. Are you working on the same thing?
Endprodukt
« Reply #6 on: May 15, 2016, 08:06:44 pm »
I had a t2 cab that i wanted to mame. Sold it. Just started to miss it but don't have the space so i got myself revx Guns. Wanted to go the arduino road but having nothing but trouble.
dremcast
  • Last login:May 11, 2017, 12:53:12 pm
« Reply #7 on: May 11, 2017, 12:53:12 pm »
Hi I'm edu I working in convert to Mame one revolution  x cabinet
I allredy set up all bouttons and pots all
Games work great using A-PAC now I'm using mamehooker
To get outputs. And using ultimarc PAC - drive to get this outputs to work
Now gun leds began to work but not sure how. To use solid state relay
I bought the one u recommend here and 24v power suplay but now sure how to make
The circuit work
I think in should got 2 wires from PAC drive to solid state relay input and the.
Other 2 wires from solid state relay one to solenoid other one to power suply and from power supley to
Solenoid ??? Not sure
syntax_x
  • Last login:October 27, 2019, 09:32:44 pm
« Reply #8 on: May 14, 2017, 02:15:16 am »
Not sure if this helps but each circuit is less than $10 parts and will activate a solenoid for the required length of time when the trigger is earthed.
« Last Edit: May 14, 2017, 02:22:41 am by syntax_x »
