Author Topic: Why do I have to deselect "Enable stretch" to get full screen?  (Read 1719 times)
fcobenitez
  • Last login:May 23, 2022, 12:36:40 pm
Is it normal that, each time I power up my cab, and launch MAME.exe, I have to go to display options, and deselect "Enable Stretch" (something like that, can't remember the right phrase but it's something like that) so that I get full screen games? If I don't, then my games run at a small square. Other than that, everything works great. I have a 9250 VGA, and I used Cools method for setting up everything with Win XP.
Everytime I close MAME and re-open it, I have to change that option.
I think I will format and do a clean re-install anyway, just so I know that I have the latest files. Just want to know if this is something that everyone else does, or just me?
krick
  • Gotta have blue hair.
Re: Why do I have to deselect "Enable stretch" to get full screen?
« Reply #1 on: May 10, 2016, 10:53:40 pm »
You need to provide more information about your hardware specs, what type of monitor, and which versions of GroovyMAME and CRT_EmuDriver you are using.
Also provide a log file from when the problem is happening.
Hantarex Polo 15KHz
GroovyMAME 0.197.017h_d3d9ex
Windows 7 Home Premium 64-bit
Intel Core i7-4790K @ 4.8GHz
ASUS Z87M-PLUS Motherboard
Jonny G
  • Last login:March 04, 2024, 05:59:46 pm
« Reply #2 on: May 11, 2016, 08:51:49 am »
Could be as simple as making sure your mame directory isn't set as read only. That would explain why your changes aren't holding.
