Author Topic: Arduino code  (Read 4783 times)
  • Last login:April 03, 2026, 11:42:26 pm
Arduino code
« on: May 08, 2016, 09:52:18 pm »
picked up an uno kit to use for a project. i'm having some difficulty with the programming (total noob here...last time i coded was in basic) i have everything fleshed out on breadboard and everything works.
i managed to piece together some code and it almost does what I want... it looks right to me, but i've been staring at it so long i'm sure i'm looking past a glaring mistake. I think it's right, but it's wrong.
basically i'm lighting a "normal status" LED....monitoring the temp of a probe....when it reaches a set value, it should shut off the output of the normal status LED and turn on another output that is a "warning" LED.
as you will see below, I have the initalization of the normal status LED so it lights on startup... it switches the other LED on when the threshold is reached as intended, but does not turn off the normal status LED as intended...and does not turn off the warning LED once back below the threshold. my if else loop looks okay but is likely wrong.
i output the temp data to the serial port to confirm proper operation, this will be removed later.
any coders out there want a laugh?
unsigned long tepTimer ;
int ledred=9;
int lednorm=11;
void setup(){
    Serial.begin(9600);
void loop(){
    int val;
    double data;
    val=analogRead(0);
    data = (double) val * (5/10.24);  // convert the voltage to temperture
    if(data>27){        // If the temperture is over 27 degrees then alarm
          digitalWrite(ledred,HIGH);
          digitalWrite(lednorm,LOW);
          delay(2);
     else { digitalWrite(ledred,LOW);
           digitalWrite(lednorm,HIGH);
           delay(2);}
    if(millis() - tepTimer > 500){     // output the temperture value per 500ms
             tepTimer = millis();
             Serial.print(data);
« Last Edit: May 08, 2016, 10:23:09 pm by lilshawn »
Re: Arduino code
« Reply #1 on: May 08, 2016, 10:28:56 pm »
changing to analogWrite and using 0/255 seems to work?
 :dunno
 is "low" actually "floating"?
« Last Edit: May 08, 2016, 10:34:14 pm by lilshawn »
ed12
Re: Arduino code
« Reply #2 on: May 09, 2016, 12:03:14 am »
ed
baritonomarchetto
  • Last login:Yesterday at 02:36:29 am
Re: Arduino code
« Reply #3 on: May 09, 2016, 03:51:00 am »
You must declare the pinMode as output for pin 9 and 11. By default, pins are set as (floating) inputs.
« Last Edit: May 09, 2016, 11:20:14 am by baritonomarchetto »
Re: Arduino code
« Reply #4 on: May 09, 2016, 05:56:53 pm »
ahhh i see.
so add in the void setup
pinMode(lednorm,output);
pinmode(ledred,output);
so declared as an output the pin is either pulled HIGH or LOW and
if left undeclared the pin is left floating after being pulled HIGH or LOW.
is there a scenario you would want this type of output? external pull up/down?
baritonomarchetto
Re: Arduino code
« Reply #5 on: May 10, 2016, 12:46:46 am »
You can pull high or low pins both setting them as input (by external trigger) or output (by internal trigger). The main difference is the high impedence of pins set as input (and other things the IDE sets for you).
When using the pin as input be sure to connect a pulldown resistor or activate the internal pullup resistor (see arduino basics for this: there are tons of examples for starters included with the IDE)
« Last Edit: May 10, 2016, 12:51:24 am by baritonomarchetto »
