Author Topic: Vertical games in horizontal resolution  (Read 1882 times)
Cisek
  • Last login:May 19, 2023, 07:35:14 am
« on: May 08, 2016, 07:25:00 pm »
Hi
My groovymame ini is set to horizontal mode, so all verical games are displayed in 4:3 ratio horizontally.
My problem is sound stuttering. When I play those vertical games in horizontally rotated mode, in a lot of games the sound is crackling.
It doesn't happen howerver if I rotate those games to their original vertical orientation.
So is there any possibility to play smoothly vertical games in horizontal irentation with groovymame?
krick
  • Gotta have blue hair.
Re: Vertical games in horizontal resolution
« Reply #1 on: May 11, 2016, 09:24:11 am »
You need to provide more information about your hardware specs, what type of monitor, and which versions of GroovyMAME and CRT_EmuDriver you are using.
Also provide a log file from when the problem is happening.
Hantarex Polo 15KHz
GroovyMAME 0.197.017h_d3d9ex
Windows 7 Home Premium 64-bit
Intel Core i7-4790K @ 4.8GHz
ASUS Z87M-PLUS Motherboard
